5100's installed on lowest/stock setting and still nose high. What's the deal???
Discussion in 'Suspension' started by hygieneboy, Jun 14, 2013.
  1. Jun 14, 2013 at 2:18 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    The installer should definitely be replaced.
  2. Jun 14, 2013 at 2:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can't tell what the damage is but if it's just cosmetic, I'd let it go. If it's dented or cracked, then make a stink about it. Looks like it's just scuffed.
  3. Jun 14, 2013 at 2:22 PM
    miacevedo
    miacevedo Well-Known Member
    SoCal
    SuperWhite 4X4
    All Pro Hybrid front bumper. All Pro rock sliders. Warn Winch. Icon 2.5 Remote Resi Coilovers & Rear Icon 2.0 Extended Remote Resi's. AP Standard leafs. Rear SuperBumps. OEM bed mat and All Weather floor mats. Pelfreybilt IFS Skid. Method NV wheels on 285/75/16 Toyo Open Country AT2.
    Did the shaft bend?
  4. Jun 14, 2013 at 2:38 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    What did the dealer charge you? I assume they did an alignment as well.
  5. Jun 14, 2013 at 2:39 PM
    whitetacoma89
    whitetacoma89 Well-Known Member
    Anaheim
    11 Prerunner
    That plate is clearly upside down. Turning that around should fix your problem immediately
  6. Jun 14, 2013 at 2:52 PM
    hygieneboy
    hygieneboy [OP] Well-Known Member
    Got a loaner for the time being until things get figured out. Grrrrrr. The truck actually seemed to drive nice and softer than stock even with an upside down spring seat and lotsa lift in the front.
  7. Jun 14, 2013 at 2:54 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Hope they fix it right and give you a discount or something as compensation for the mess-up.
  8. Jun 14, 2013 at 4:47 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Reason #1 you should do this stuff yourself. It is easy. If you cant do it get very familiar with the install procedures then verify that the mechanic has done it correctly before you even drive off with it. Shit like this flat scares me. Hell if I was the mechanic i'd be afraid to even take this off because there is nothing keeping that spring plate clip in place other than the spring pressure trying to push the clip it down and out. In this situation I would use the floorjack under the LCA and relieve the spring pressure with the floorjack after removing the top stem nut....would not want that coil over sittin on the bench unrestrained.
  9. Jun 14, 2013 at 5:07 PM
    whitetacoma89
    Anaheim
    11 Prerunner
    Hopefully your 5100s aren't messed up... with that kind of pressure... who knows what has already been damaged. Good luck bro this situation sucks for u
  10. Jun 15, 2013 at 6:00 AM
    hygieneboy
    I just got a call. My Toyota dealer has ordered some new 5100 front shocks and will install them Monday when they arrive. The tech who originally installed them told me he was driving back and forth over speed bumps to settle the springs.
  11. Jun 15, 2013 at 6:07 AM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    Where do they find some of these techs????
  12. Jun 15, 2013 at 6:34 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    He should start a new career AS a speed bump.
    It seems he would have a greater aptitude for this.
  13. Jun 15, 2013 at 6:37 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    haaa!
  14. Jun 15, 2013 at 6:43 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    lol
  15. Jun 15, 2013 at 6:57 AM
    #35
    hygieneboy
    My local aftermarket truck shops all quoted around $350 to install the shocks/alignment and none seemed too keen to work on a Toyota. My Toyota dealer is closer and quoted me $225. And who knows how to work on a Toyota better than the dealer I thought :rolleyes: I'm not perfect. I make mistakes...... but damn! I went round and round with them to get a rental/loaner w/o putting my credit card down(their GM used his) and to get new front 5100 shocks but it seems that they are trying to make things right. Let's see if I somehow don't get invited to fill out a survey this time:cool:
  16. Jun 15, 2013 at 6:59 AM
    #36
    BulletToothTony
    That's sucks to here OP. but at least they are fixing and replacing them and you got a free rental too.
  17. Jun 15, 2013 at 7:13 AM
    #37
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    Jeez that's bad. I'm glad you got everything all straightened out but man what a headache. This is why i'm a big DIY fan, at least if I mess it up, I only have myself to blame.
  18. Jun 15, 2013 at 4:42 PM
    #38
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Thanks for the price info. I'm going to see what my dealer will charge for the same thing next week.
  19. Jun 15, 2013 at 5:02 PM
    #39
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I took my Bilsteins with eibach coils to a shock and strut place. My thought was they know what they are doing, I'm sure they can put my Coilovers together for me so I can take them home and install them. Plus they had a wall mounted spring compressor, so they must have done stuff like this before...
    Nope!!! Never doing that again. They had no clue what they were looking at. I had researched and personally, I knew what to do, I just didn't want to deal with compressing the spring. Well I ended up doing it myself at that shop. They let me do it myself and I didn't have to pay anything. I'm not gonna trust anyone with installing things on my truck unless I'm right there to watch every step!
    Good luck OP! Hope every thing turns out as it should!
  20. Jun 16, 2013 at 7:58 PM
    #40
    whitetacoma89
    Anaheim
    11 Prerunner
    Keep us updated op! You should definitely ask them to comp the labor!
