5100's ? Just front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lelandt, Jan 13, 2017.
  1. Jan 13, 2017 at 7:52 AM
    Lelandt
    Lelandt [OP] Well-Known Member
    Tavish
    Maine
    08 TRD OR
    bully bull bar, halo/angle eye headlights, 20" cree led light bar mounted on bull bar. 42" radius light bar from extreme LEDs 2 led pods, Spare tire mount on bed
    I would like to put 5100 adjustables on. Just wondering what is needed for just the front end. Do I just need the the shocks? I know I can use stock springs. Looking to do this and aal in the back. I've been looking around and most info is on the whole kit. Thanks.
    ChadsPride likes this.
  2. Jan 13, 2017 at 8:33 AM
    Pigpen
    Dan
    Northwest Montana
    All you need for the front is the new shocks. Once you have everything installed at the desired setting, you'll know how much lift to do to match the rear.
    My access cab got 2.5" of lift from 5100s set at the 1.75" setting with stock springs. A DCLB will get closer to the "average" 1.75" at that same setting.
    Lelandt[OP] and ChadsPride like this.
  3. Jan 13, 2017 at 8:35 AM
    Lelandt
    Tavish
    Maine
    08 TRD OR
    Thank you just what I wanted to know
  4. Jan 13, 2017 at 8:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    5100's are not adjustable. At least not in the sense of real adjustable shocks, where the damping rate is adjustable.
    5100 is a moderately better than OE shock that has 3 fixed spring perch locations. Selecting anything above 0 (stock) preloads the spring to create lift. At the expense of spring travel and at the risk of spring binding.
    If you want lift, pick the right spring for the job, and then the right damper for the job at hand. If the 5100 is rated to control the spring selected, then use the 0 setting for max travel, ride, etc.
    Don't know what spring to pick? Call Marie @HeadStrong Off-Road. Know the answers to her questions, and you'll get the right gear.
  5. Jan 13, 2017 at 8:42 AM
    Lelandt
    Tavish
    Maine
    08 TRD OR
    So it's like having a spacer lift without a spacer if it's set higher?
    ManBeast likes this.
  6. Jan 13, 2017 at 8:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not at all.
  7. Jan 13, 2017 at 8:45 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If buying just the shocks and using the stock coils, you will most likely need to buy new bushings for the shocks and rubber top hats for the top of the struts. Mine on my 09 are worn out, so this is something ill be replacing while i have them apart
  8. Jan 13, 2017 at 8:46 AM
    Pigpen
    Dan
    Northwest Montana
    Bill is mostly right here.
    The 5100s ride great IMO at the setting I ran them. I did upgrade to new coils and the ride is better, but there was nothing wrong with the running the preloaded setup if your looking to lift on a budget.
    Lelandt[OP] likes this.
  9. Jan 13, 2017 at 8:47 AM
    Pigpen
    Dan
    Northwest Montana
    OP, the information above is good advice for your '08.
    The 5100s do come with new washers and bushings for the stem though.
  10. Jan 13, 2017 at 9:02 AM
    BassAckwards
    Mine didnt when i got them.. think it depends on the place you get them from
  11. Jan 13, 2017 at 9:06 AM
    Pigpen
    Dan
    Northwest Montana
    That's odd, I've bought 2 pair for my truck and installed another for a friend. Each of the 3 sets came from different places and had the bushings and washers in the factory boxes.
  12. Jan 13, 2017 at 9:33 AM
    Lelandt
    Tavish
    Maine
    08 TRD OR
    Thanks guys. This will be my little gift to my self for tax return season haha
    BassAckwards and Pigpen like this.
  13. Jan 13, 2017 at 9:39 AM
    Pigpen
    Dan
    Northwest Montana
    Marie @HeadStrong Off-Road will take good care of you
    Lelandt[QUOTED][OP] likes this.
  14. Jan 13, 2017 at 2:20 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    PM sent! thank you so much @Clearwater Bill and @Pigpen ! Hope you guys are having a wonderful Friday!!! :cheers:
    Pigpen[QUOTED] likes this.
