5100s max out + toytec AAL = not level :((
Discussion in 'Suspension' started by magixfinger, Feb 28, 2011.
  1. Feb 28, 2011 at 6:17 AM
    magixfinger
    magixfinger [OP] Well-Known Member
    Tail gate mod | shorty antena mod | K&N drop in filter
    hi guys, I just installed my 5100s last week on all 4 corners with the toytec AAL for TSB and the result was not what I expected, the ride quality is very good, a lot better than stock ride quality. What I', concerning is the look of it, it is NOT level at all, may be it just me but you guys can look at the pictures and tell me is it level or not, I think it is nose down. Can any one tell me what I can do to make it level, I don't want to go above 3 inches because to what I know if you go above 3 inches there is a lot of part needs to be replace. Thanks guys for looking, comments and inputs are welcome
    http://www.tacomaworld.com/forum/[ATTACH=full]1771118[/ATTACH][U][ATTACH=full]1771118[/ATTACH]
    [ATTACH=full]1771121[/ATTACH]
    [ATTACH=full]1771127[/ATTACH]
    [/U]
    [IMG]http://s1189.photobucket.com/albums/z421/magixfinger/?action=view&current=DSC02326.jpg
  2. Feb 28, 2011 at 6:22 AM
    TacoMatt02
    TacoMatt02 Well-Known Member
    South Carolina
    02 sr5 double cab
    looks level to me :confused:
  3. Feb 28, 2011 at 6:23 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    the AAL will settle slightly, but did you use a 1.5" or 2" AAL?
  4. Feb 28, 2011 at 6:23 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    You don't say what the front 5100's are set at
  5. Feb 28, 2011 at 6:27 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    looks pretty close to level. give it about a month and the rear sould settle a little bit.
  6. Feb 28, 2011 at 6:28 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    x3
  7. Feb 28, 2011 at 6:30 AM
    TacoSupreme
    TacoSupreme Well-Known Member
    Cuatro Por Cuatro
    Looks level from your pic angles. Prob jus need to give it some time to settle.
  8. Feb 28, 2011 at 6:38 AM
    magixfinger
    I have the 5100s set at 2.5 and I have the factory TSB plus the toytec 1.5 TSB, so 5 leaf pack total.
  9. Feb 28, 2011 at 6:39 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    bigger tires on the front and smaller ones on the back. haha jk listen to what they said ^^^
  10. Feb 28, 2011 at 6:39 AM
    raswank
    Rick
    Auburn,Ma
    The TSB is only 4 leafs. Give it some time to settle
  11. Feb 28, 2011 at 7:09 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    It will settle a little bit. My rear was really high when I first installed my 2" AAL. I have the same setup.
    One thing to keep in mind is that the rear wheel wells are cut a little higher than the front to accomodate for hauling heavy loads.
  12. Feb 28, 2011 at 10:56 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    other people on here have the same setup and they're level, so i imagine yours should settle in no time like others have said.
  13. Feb 28, 2011 at 11:06 AM
    creeper
    creeper Well-Known Member
    It's in the title...
  14. Feb 28, 2011 at 11:07 AM
    creeper
    "I have the factory TSB plus the toytec 1.5 TSB, so 5 leaf pack total."
  15. Feb 28, 2011 at 11:21 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    TSB gives you about 1" lift. The Toytec TSB AAL gives 1.5".
    So you have 2.5" in the rear, 2.5" in the front....why are you surprised that you have the same amount of rake as you did stock? :confused:
  16. Feb 28, 2011 at 2:26 PM
    KPT
    09 Prerunner
    The folks who run 2.5" up front, 1.5" rear to be level do not have the TSB.
  17. Mar 1, 2011 at 5:34 AM
    magixfinger
    I don't know why you said that but it is my truck and I know how many leaf are on my truck, there are a total of five now. First was the original 3 leafs when I purchase the truck, then come the TSB which added another leaf make it 4 leafs and I just added the one from toytec which make it five leafs total. As per Chris4x4 DYI, you can see the total of 5 leafs in his pictorial illustration.
  18. Mar 1, 2011 at 5:48 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    He understands you have 5 leafs but what he's saying is that you need to let that pack have time to settle and then some more time for the AAL to settle as well.
    My TSB springs took a week to settle to where they are now.
  19. Mar 1, 2011 at 5:51 AM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    looks good man really close to level
  20. Mar 1, 2011 at 5:53 AM
    jdcrowe75
    jdcrowe75 Well-Known Member
    North Florida
    2010 DC TRD OR 4x4
    I've got the same truck and I had the same problem. Set the 5100s at 2.5, did the TSB, added a 1.5 AAL. Ride was great but too high in rear. Took the AAL off and now I've got the look I like and still rides great. You might want to give it a try.
