5100's on a 17 Access cab
Discussion in 'Suspension' started by Jpuch, Jan 26, 2017.
  1. Jan 26, 2017 at 9:34 AM
    Jpuch
    Jpuch [OP] Active Member
    2017 Tacoma TRD OR
    None yet
    im looking to add 2-3" to my 17 TRD OR. I was ready to go with 5100's but now I have seen a couple mentions about not setting to #5 if they are installed on a v6 access cab. I can't find any explanation why! Anyone know what is up with that?
  2. Jan 26, 2017 at 10:21 AM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    Supposedly the ACabs will sit higher in the front than DCabs
  3. Jan 26, 2017 at 11:04 AM
    Jpuch
    2017 Tacoma TRD OR
    None yet
    I see what your saying. I think. Basically, setting 5 will result in more than max increase and could cause other issues. Is it safe to assume for example, that setting 4 on my access cab could be the same as 5 on a Dcab?
  4. Jan 26, 2017 at 11:14 AM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    Yes, be advised you may need to go to aftermarket control arms
  5. Jan 26, 2017 at 12:07 PM
    Jpuch
    2017 Tacoma TRD OR
    None yet
    I went with a 3/2 level kit (spacers) and 35" tires on stock rims for my Tundra and didnt really like the ride, had to cut the inner fender, add wheel spacers, and maxed out my alignment. For my Tacoma, Im trying to keep the ride comfort and get 2"-3" max lift without maxing out my alignment or the added expense of UCA's. Also want to keep stock rims so I dont mind adding 1.25" spacers if need be. Guess im asking too much?
  6. Jan 26, 2017 at 12:55 PM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    What size tires are you looking to run?
  7. Jan 26, 2017 at 1:14 PM
    Jpuch
    2017 Tacoma TRD OR
    None yet
    I'm more interested getting to the 2-3" height then I'll see what I can fit without making any other adjustments/modifications except for wheel spacers if needed.
  8. Jan 26, 2017 at 1:15 PM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    Front and rear? or just doing a leveling system?
  9. Jan 26, 2017 at 1:26 PM
    Jpuch
    2017 Tacoma TRD OR
    None yet
    Id like the same lift (2"-3") front and back. Im not sure why the engineers have that lower front end look. But maybe its best to stay with the same rake or stance?
  10. Jan 26, 2017 at 1:27 PM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    There's no harm in leveling it. Usually the rear is higher so it won't sag when you're hauling stuff
  11. Jan 26, 2017 at 1:44 PM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    they lift the rear so when you put weight or tow, it'll sag to level.
  12. Jan 26, 2017 at 1:44 PM
    Jpuch
    2017 Tacoma TRD OR
    None yet
    After I did the 3/2 readylift on my Tundra, I wasn't happy with the ride. Loved the look but when I went off road, it seemed to have a clunking sound under some conditions and the front travel seemed to bottom out on wimpy bumps. I don't go wheeling much but when I do it isnt extreme.
    Im just being cheap I guess. I'll have to stop whining and spend some $$.
  13. Jan 31, 2017 at 1:11 PM
    Jpuch
    2017 Tacoma TRD OR
    None yet
    Thanks to those who responded to my question. Here's another one regarding the 5100's. If putting a spacer on top of the spring (preload spacer) is bad according to some people. How is raising the bottom of the spring up (setting 1,2,3,4,5) OK? Isn't it the same thing? Ones on top of the spring and one is effectively on the bottom. Either way the spring is being preloaded. So why spend the $$ on 5100's if spacers are waaaay less?
  14. Feb 1, 2017 at 11:47 AM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    "adding a spacer on top of the strut adds length to the strut assembly, causing the strut to be too long and allowing it to droop farther than what it would factory."
  15. Feb 1, 2017 at 9:28 PM
    Nate250f
    Nate250f Member
    Nate
    2007 6 speed tacoma
    Bilstein 5100 front and rear, URD short throw shifter, bumper, lights.. bunch of little stuff
    Are you talking about the spacer in between the coil and the top plate or are you talking about the spacers that goes on top of the top plate?
  16. Feb 2, 2017 at 7:52 AM
    Jpuch
    2017 Tacoma TRD OR
    None yet
    Yes, I was talking about the spacer that goes between the spring and top plate. Not my choice of lift, just commenting how it seems like they both do the same thing. One for far less $$.
  17. Feb 2, 2017 at 8:11 AM
    Nate250f
    Nate250f Member
    Nate
    2007 6 speed tacoma
    Yep!! I agree the spacers that go between the coil are bad and preload the spring making the riding terrible and destroy your suspension components, I had a spacer on top of the coilover design, kind of like a top plate, imo if someone has to get a spacer they should use those instead
  18. Feb 2, 2017 at 12:03 PM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    i was talking about a spacer that bolts onto the top of the strut, the one that goes in the strut is in theory the same as using bilstein5100 and raising the spring plate up to the top notch, same thing.
  19. Feb 2, 2017 at 12:08 PM
    Nate250f
    Nate250f Member
    Nate
    2007 6 speed tacoma
    Ohhhh miscommunication!! I've had a spacer lift before that goes on top and it wasn't the worst.. at least for me, I had to get am alignment but it did ride but the spacer that compresses the spring imo
