5100's or 3" toytec?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by basktaco, Oct 14, 2008.
  1. Oct 15, 2008 at 6:39 PM
    #61
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I got it done back in May, I think it settled a little but not too much. I def need to get something in the front to level it out.
  2. Oct 15, 2008 at 6:43 PM
    #62
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    oh........thought you may have just had it done recently. my bad. yeah.....5100's should do it for ya then man. setting them on 1.75 may level the truck for you instead of setting them at 2.5. get them from downsouthmotorsports on ebay if you decide to get some.....great deal from them.
    #62
  3. Oct 15, 2008 at 6:45 PM
    #63
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    so far mine hasn't settled at all over the last 6 months. it is just as level as it was. i wouldn't mind adding another inch in back just to be safe but its still level
  4. Oct 15, 2008 at 6:48 PM
    #64
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hell....if you are gonna do that, you may as well get a new set of coilovers and an aal for the rear. ride would be better than a block. of course, you'd sit a bit higher than you are now.
  5. Oct 15, 2008 at 7:07 PM
    #65
    nd
    Nate
    Greenville, SC
    oh i wont be using blocks, i may eventually get a leaf set
  6. Oct 15, 2008 at 7:12 PM
    #66
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good set of deavers or alcans....or just an aal, along with a set of ome coils.....you'd be set man. and maybe a set of tc uca's later on!!!:D
  7. Feb 25, 2009 at 10:35 PM
    #67
    TrdPETE
    TrdPETE Well-Known Member
    Maui
    08 double-cab 4x4
    TSB, Motto Metal 954, 5100s all around, front set @ 2.5, M/T baja atz radial, 285/70/17,Kenwood dd712,halo cccf,de-badged
    5100s set at 2.5, rear tsb only. 285/70/17
  8. Feb 26, 2009 at 1:53 AM
    #68
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    Very nice Pete. Ddi you have to cut any plastic to fit those tires?
  9. Feb 26, 2009 at 4:31 AM
    #69
    Burns
    17 DCSB Off-Road
    Interesting, nothing but the TSB in the rear. [​IMG]
    Sweet looking truck BTW !
  10. Feb 26, 2009 at 8:37 AM
    #70
    nd
    Nate
    Greenville, SC
    my tsb was higher than most peoples too. i have my front set at 2.5 and the back is still barely level with it. it was better a year ago but has dropped a little bit
  11. Feb 26, 2009 at 8:43 AM
    #71
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Same here. I only have the rear TSB and my coilovers are about 3". Now that the rear has settled, my front is just a touch higher than the rear.
    Mileage varies with the height you get out of the TSB springs...
  12. Feb 26, 2009 at 1:41 PM
    #72
    TrdPETE
    Maui
    08 double-cab 4x4
    I had some minor trimming up front. I thought it didn't rub.
    But I went into a dip in the sand at full left turn and it did rub on the frame.
    very slight.[​IMG]
  13. Feb 26, 2009 at 5:25 PM
    #73
    warchi81
    warchi81 Active Member
    M Yota that is a nice rig. I hope to do the same to mine at some point. Is it necessary to lose the mud flaps to stop rubbing? Also in your info you say you have a 1.5" fab tech AAL. Did you do this instead of the TSB
