5100's or something else to offset steel bumper weight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stinger Flinger, Apr 25, 2016.
  1. Apr 25, 2016 at 6:26 PM
    Stinger Flinger
    Stinger Flinger [OP] Well-Known Member
    2015 Tacoma Double Cab, 4x4 TRD Off Road
    None yet...
    I am getting a new set of bad ass Pelfreybilt steel bumpers front and back (before and after pics to come) for my 2015 DCSB TRD Off Road and am thinking I will need to get some suspension upgrades to fight the sag. I will running my stock Rugged Trails for the rest of the summer, but will upgrade those at some point.
    My question is will a set of Bilstein 5100s cover the extra weight or do I need to do something a little more ($).
    If the Bilstein 5100s would do, what setting would they need to be set at?
    PS: I am not entering the Baja 1000 or trying to be a stadium truck. My truck is used for hunting and for work which can sometimes take me to remote and muddy places. Lastly, I want the truck to be rugged and look bad ass (hence the Pelfreybilt). The truck will be used 90% on road (daily driver) and 10% in the woods (but not high speed romping)
    Thanks!
  2. Apr 25, 2016 at 7:49 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    do it right the first time, grab a set of ome coils and struts and dont worry about it. preloading 5100 with stock coils will give you a super stiff ride. 886 coils if you decide down the road to add a winch or double up on batteries.
    IronPeak likes this.
  3. Apr 25, 2016 at 7:52 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    886. 887
  4. Apr 25, 2016 at 7:52 PM
    Pigpen
    Dan
    Northwest Montana
    As mentioned above, pair your new shocks/ struts with appropriate springs.
  5. Apr 25, 2016 at 9:25 PM
    RobD
    RobD Well-Known Member
    Rob
    Calgary
    2013 Spruce Mica Tacoma Double Cab TRD
    Shocks do little to support weight. They dampen the compression and rebound of the springs. Springs support the weight.
    Like has been said, pair a good set of springs with a good set of shocks.
  6. Apr 26, 2016 at 4:34 PM
    Stinger Flinger
    None yet...
    After reviewing more of the site and your suggestions, I am thinking OME 886 Coils and possibly 90000 shocks for the front. The rear still has me confused. Thinking an add a leaf but am reading conflicting info on the appropriate OME rear shock for the 2015 DCSB TRD Off Road.
