5100s or springs
Discussion in 'Suspension' started by moeb, Oct 5, 2012.
  1. Oct 5, 2012 at 1:05 PM
    moeb
    moeb [OP] Member
    moe
    baltimore
    06 SR5
    hey i have 2006 sr5 i wanted to level the front should i only get the 5100s for the front set at 1.75 or should i also replace the stock coils with the eibach and set the 5100s at .85.
    thanks
  2. Oct 5, 2012 at 1:07 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I depends if you have the $$$.
    The better option would be to have eibach springs and 5100's because there would be less preload on the spring giving you a smoother ride.
  3. Oct 5, 2012 at 1:08 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Over 100k miles? might as well replace the springs.
  4. Oct 5, 2012 at 1:30 PM
    moeb
    moeb [OP] Member
    moe
    baltimore
    06 SR5
    hey guys yes i rather get the 5100s with the springs i heard some people say that u shouldnt use the 5100s with aftermarket springs.so do u think that the 5100s set at .85 with eibach springs should level the front.the truck has 62000 miles on it .
    thanks
  5. Oct 5, 2012 at 1:37 PM
    TotalBrutal
    TotalBrutal Well-Known Member
    Dan
    Vancouver Island, BC
    2007 V6 4X4
    Front 5100s @ 0, OME 844s, Rear 5100s, AFE pro dry filter
    5100s @ 0 with Eibach should level (or come close to, pending if you have the rear 4 leaf pack). Also, OME 884 springs with 5100s @ 0 would also work. I have this set up and i'm damn near level (bout 1/2-3/4" higher in the rear).
  6. Oct 5, 2012 at 5:01 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I don't remember exactly but I believe the eibachs alone will get you close to level.
  7. Oct 5, 2012 at 5:33 PM
    moeb
    moeb [OP] Member
    moe
    baltimore
    06 SR5
    thanks guys its nice to hear from people who have done it.i have the 3 leaf spring model iguess that was on the older models. i'll get the springs and shocks
