5100s question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stmpjmpr, Dec 29, 2012.
  1. Dec 29, 2012 at 10:47 PM
    stmpjmpr
    stmpjmpr [OP] Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Im lookin at 5100's with 2.5" adj. will they fit with me having 305/65/17's? I currently have a 3' spacer but would like to remove it in place of the billies
  2. Dec 30, 2012 at 2:59 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Jimmy, I was rubbing all over with 285's and my old Billies set to 2.5. You COULD make it work but you'll need to do a good amount of trimming the splash guards as well as possibly chopping the cab mount. I still rub my cab mount when I'm flexed even with 265's.
  3. Dec 30, 2012 at 5:30 PM
    stmpjmpr
    Jimmy
    txs traveler anyone else?
  4. Dec 30, 2012 at 5:33 PM
    06sr5prerunner
    06sr5prerunner DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    running them @ 1.75 with 285/75r16 and eeeh its not bad rub a littl now and then idk think you will have much of a problem just slight trimmiing assuming you will have them at 2.5
  5. Dec 31, 2012 at 11:52 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    But the spacer is also needed to prevent rubbing on the wheel knuckle, unless you get new wheels with the appropriate backspacing.
    I take it you have aftermarket UCA's? At the 2.5 setting and with 265/70-17 tires, my alignment setting is at the max. Any larger tires and I will need new UCA's.
  6. Dec 31, 2012 at 1:45 PM
    The Traveler
    SoCal
    Not necessarily. I ran on a 2.5" lift with 33" tires with stock UCA's for a few months, and it aligned no problem. I eventually upgraded to All Pro uniballs to complete my mid-travel.
  7. Dec 31, 2012 at 2:09 PM
    Chuy
    Lakeside, CA
    Silver Taco
    On 17-inch wheels? That's about 1.5 inch greater diameter than mine. Was the tech guy joshing me? Maybe your 2.5 lift was a little lower due to oldem springs or front-end weight? Point is, it's something to keep in mind.
