5100s same length
Discussion in 'Suspension' started by Cnasianfire, Feb 2, 2020.
  1. Feb 2, 2020 at 3:43 AM
    Cnasianfire
    Cnasianfire [OP] Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    So I got 5100s put on my 2015 taco. I love them! But I have been reading about them and they are the same length. I thought that the left and right sides are different lengths for stock shocks. So why does the 5100s work when they are the same length? I am a newbie to suspensions
  2. Feb 2, 2020 at 4:31 AM
    Cnasianfire
    Charles
    Wilmington, NC
    I guess my question is, is it okay that they are the same lengths and why when stock shocks are different lengths
  3. Feb 2, 2020 at 4:44 AM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    All shocks are the same length, but the stock coils aren't rated for the same weight. The stock driver side coil is rated for a heavier weight because the gas tank, and driver are both on the left side of the truck meaning that the driver side would be lower if the stock coil rates were the same for the driver and passenger side
    whatstcp likes this.
  4. Feb 2, 2020 at 6:23 AM
    Cnasianfire
    Charles
    Wilmington, NC
    So OEM shocks for the Tacoma are the same length??? I get the coil and spring issue. But I thought that the shocks were different lengths
  5. Feb 2, 2020 at 8:46 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Yes the shocks are the same. Coil springs just have a different rating due to more weight on drive side
  6. Feb 3, 2020 at 5:21 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Thanks. I was just wondering because the left side, the boot is a bit squished vs the right (passenger side). Just wondered the difference.
  7. Feb 3, 2020 at 5:39 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    “Some” put spacers (nominally 1/4 inch), on the driver front coilovers. Some coilover sets come setup on different height clips/rings. This is to compensate for the driver side lean caused by the weight of gas tank and drivers butt.
    The boot is squished because the boot is squished.
  8. Feb 4, 2020 at 7:56 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Sorry, I meant to say that the 5100s that I am talking about are the rear ones, not the front ones
  9. Feb 4, 2020 at 8:01 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    The boots slide around under compression and extension. The accordion design is supposed to allow them to move but in reality they get kinked up pretty quickly. That is of no consequence since the boots are a guard for the internal component of the shock. If it bothers you, get under there and adjust the boot and cinch it hard with a zip tie on the top... it won't stay correctly positioned for long though...
  10. Feb 4, 2020 at 8:06 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Thanks guys
  11. Feb 28, 2020 at 6:04 AM
    Timothy Quinn
    Timothy Quinn Well-Known Member
    2001 TRD OFFROAD SR5 and 2018 TRD OFFROAD
    So this would explain why if you buy the Bilstein 6112 with coil springs you set the snap ring at a different notch from driver side to passenger side, but with the 5100's you are using the stock coil's so you set both of them the same
