5100s set at 2.5 help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NOAH, Sep 9, 2009.
  1. Sep 9, 2009 at 6:47 PM
    NOAH
    NOAH [OP] Member
    Orlando, Florida
    08 PreRunner SR5
    Detroit TrueTrac, 5100's x4 set @ 1.75, TSB AAL, Flowmaster 50, AFE CAI, 16" Raceline Renegade 6 wheels, 265/75/16 General Grabber AT2s, Color matched grille, Cleared-out headlights, 15% tint front 30% tint rears and back, Peripheral iPod adapter, Heavy-Duty vinyl armrests, Hard wired GPS, Sockmonkey badging
    Need some opinions-
    I have a set of bilstein 5100s in the garage waiting for install. I plan on getting some 265/75/r16 tires before they go on. I have the TSB springs which has the rear quit a bit higher in the rear. The question is if I set the bilsteins at 2.5" what will have to be done to the rear? 1 inch block, 1.5" toytec TSB AAL. Or is it best to set the fronts to 1.75 and call it a day. I want an aggresive stance, like a bit of rake, don't need it to look like a monster truck but want it to look lifted.
    Decisions, decisions....
  2. Sep 9, 2009 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would set at 1.75". That way, No alignment issues, and no need to mess with the rear.
  3. Sep 9, 2009 at 6:51 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    If you can live with getting them set at 1.75 then do it. LIke chris said, you wont have alignment issues. I just put my 5100s on and set them at 2.5 with some 285s and I'm having some alignment issues. I'm gonna have to spend another $600 on some UCA's to correct it so if possible, I would get it set at 1.75.
  4. Sep 9, 2009 at 6:59 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    gotta go with chris here. you will have a very slight, if not level looks. cv joint angles will be fine. no need for uca's. and alignment will be fine. 1.75" ftw
  5. Sep 9, 2009 at 7:01 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I've got mine set at 1.75" in front, and while it is a great height for the front, I also have an AAL in the back in addition to the TSB leaf pack. I like the look as it maintains the factory rake. If I load the bed, the truck doesn't sit nose high.
  6. Sep 9, 2009 at 7:02 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    ^^^ i want this setup. sucks for me, no tsb :eek:
  7. Sep 9, 2009 at 7:21 PM
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    I just had mine done at 1.75 and my taco alligned with no problems. It doesnt pull, drift,or wonder....perfect....and i should be able to put some 265/75/16's on
  8. Sep 9, 2009 at 7:57 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    just an fyi, you can fit 265/75's with stock suspension
    though i do plan on going the 5100 route also, cause they fill the front fenders up pretty good.
  9. Sep 9, 2009 at 8:33 PM
    gcwaterski
    gcwaterski Well-Known Member
    I have mine set at 1.75 with BF all-terrain 265/75-r16 tires and the rear TSB. I love it so much more than stock also. If you are going with a 265 and don't want to have to fool with the back or anything, this is the way to go!
    ....But I have to say- I wish I had gone with 2.5, because I want 285's. I am going to bump mine up with an AAL in the back. I really want 285's :D
  10. Sep 9, 2009 at 8:44 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    True. I too will be adding 5100's.
  11. Sep 9, 2009 at 9:32 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    heres my 5100 set at 2.5 with non tsb AAL in the rear:
  12. Sep 10, 2009 at 9:45 AM
    NOAH
    NOAH [OP] Member
    Orlando, Florida
    08 PreRunner SR5
    Right now the 1.75s are winning. I will probibly go with that no desire for new UCAs. Thoughts on the 1.5 AAL + TSB? Too high in the rear? right now with a stock front end the rear sits2.75" higher.
  13. Sep 10, 2009 at 9:55 AM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    ^ +1
    im non TSB and just ordered some 1.5 AALs. Trying to kill to birds with one stone. thanx
    G
  14. Sep 10, 2009 at 9:55 AM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    gcwaterski, I want to see a pic of your truck...I'm on the fence and have 5100's sitting in the corner waiting for install.
  15. Sep 10, 2009 at 11:25 AM
    gcwaterski
    ^^^ Do it, no vibes and they ride GREAT.
    ^^^Excuse the tree but this shows the fender gap on the front pretty well :)
  16. Sep 10, 2009 at 11:41 AM
    beginah
    beginah Well-Known Member
    I have mine set at 2.5 with a toytec 2" AAL and the back sits about 0.5" higher. My camber is within spec, but caster isn't.
  17. Sep 10, 2009 at 11:56 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    same with me. I need to get it all checked.
  18. Sep 10, 2009 at 12:02 PM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    check my album. Im running the 5100 at 2.5 with AAL and stock tires. I might go with gcwaterski's tires when mine wear out tho
  19. Sep 10, 2009 at 12:39 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
  20. Sep 10, 2009 at 2:00 PM
    Good351
    Ames, IA
    03 4Runner V8
    gcwaterski, Thanks for the pics! My truck is exactly like yours, even silver. Truck looks good!
    I do really want 285's though too, so I'm still on the fence... If I do 285's I'll probably re-gear to 4.10's because I pull a boat pretty often. I just don't want to spend the extra $$$ right now to re-gear.
