5100s Tacoma Lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deadbolt, Apr 1, 2009.
  1. Apr 1, 2009 at 1:25 PM
    deadbolt
    deadbolt [OP] do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    I just recently installed the adjustable 5100s on my truck.
    When i compare the two sides, driver and passenger sides, the driver side is lower than the passenger side by alittle more than 1 inch. (exact is 1 inch and a half). I know some poeple are experiencing this but is 1 inch difference normal? Chime in if you guys have had this problem. Thanks
  2. Apr 1, 2009 at 1:28 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    Do guesses count???
    I'm thinking full gas tank? Check the measurement between full & empty.
    But 1 1/2" seems like ALOT!
  3. Apr 1, 2009 at 1:31 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    I had the same problem with my new lift. get Toytec part number TP14 1/4" top plate spacer to get back about a 1/2". mine is only lower by 5/8" now on the drivers side which believe it or not is alot less noticeable
  4. Apr 1, 2009 at 1:54 PM
    Joe B
    Joe B Well-Known Member
    DK,these TP14s will fit the 5100s?:)
    Do I need to buy two to get that 1/2"?
    The plates are a 1/4 but Toyotec says one will add 1/2".
    Front Top Plate Spacer (One - 1/4")
    Price (Each): $19.99
    TP14 ---
    Top plate spacer adds approximately 1/2" lift. Great for correction of drivers side ride height. Includes 1 spacer
  5. Apr 1, 2009 at 1:55 PM
    Shanes56
    Shanes56 Sittinsic.com Vendor
    WI
    07 BSP X-Runner Sittin Sic
    Ask and I will tell you... Sittin Sic Drop Leafs and Coils
    Here is a funny little bit of information I learned from TRD this past week. 05+ tacomas have the taco lean from not only being heavier on one side as compared to the other. Also some tacos came from the factory with frame that was not true, and guess what they can all be pointed directly to the indiana factory, odly enough not a toyota factory a GM factory. haha, great stuff
  6. Apr 1, 2009 at 1:59 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Right, it is a 1/4" spacer but the lift ratio is 2:1 so that 1/4" spacer will in fact give you a half inch lift. DO NOT STACK SPACERS! plus the top plate studs will not be long enough to cover that anyway. They should definitely fit the 5100's because the spacer fits on top of the coilover, not between the spring and top plate.
  7. Apr 1, 2009 at 2:00 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    SOB's
  8. Apr 1, 2009 at 2:01 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I know on the first gen trucks - the coils are side specific. The drivers side coil has an additional winding in it.
    Not sure if the 2nd gens are like that or not.... and if they are, is it possible you got the coils mismatched from side to side?
    Try swapping the coil assemblies and see what it does.
  9. Apr 1, 2009 at 2:07 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    :eek: I never knew that!
  10. Apr 1, 2009 at 2:10 PM
    deadbolt
    Socal
    Thanks guys for ur replies.
    So if i understand this correctly, for the top plate i do not have to take out the coil from the shocks?
  11. Apr 1, 2009 at 2:13 PM
    Joe B
    DK,the geometry thing is over my head.
    I called Toytec and was told the same.
    Thanks for the part lead.:)
  12. Apr 1, 2009 at 2:13 PM
    deadbolt
    Socal
    Does anyone have pictures of the top plate installed?
  13. Apr 1, 2009 at 3:37 PM
    Janster
    Jandy
    Lancaster, PA
    Old picture off a 1st gen... but this is the entire coil/strut assembly as its removed from the vehicle.
    The top plate spacer will have 3 holes and it just slaps onto the assembly and you mount the entire thing inthe truck.
  14. Apr 1, 2009 at 3:59 PM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    X2.
  15. Apr 1, 2009 at 4:14 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Do you have any documentation or a credible source to back that up? I'd like to look into where my '08 was built since my lean is about 1"+.
  16. Apr 1, 2009 at 4:15 PM
    deadbolt
    Socal
    You are experiencing a 1" lean too? im not alone!!
  17. Apr 1, 2009 at 4:19 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    i have 1/4 inch lean to the driver side with full gas, i have coilovers and did not notice it with the 5100's. i will check when i am low on gas.
  18. Apr 1, 2009 at 4:29 PM
    grivera
    Hanover, MD
    Do a search and youll find plenty-many may not be an inch though.
    I'm a bit po'd about Toyota's failure to address this issue. The dealer told me that 1/2" is within tolerance but offered no solution for my 1" +. I don't see how a manufacturer lets this get by.
  19. Apr 1, 2009 at 4:33 PM
    deadbolt
    Socal
    Was this before or after you put on ur 5100s?
  20. Apr 1, 2009 at 4:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Dana Corp makes all the Tacoma frames. regardless of where they are installed on the boddy/chassis. The frames are going to have a tolerance of some kind, but Im not sure if that corelates to the lean.
    Deadbolt, Jansters is correct. The Tacomas have a driver and passenger side specific spring. Try swapping sides and see if that fixes the issue.
