5100's to front only ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jakeda, Mar 17, 2015.
  1. Mar 17, 2015 at 11:01 AM
    jakeda
    jakeda [OP] Well-Known Member
    denver
    2015 dbl cab LB
    n/a
    has anyone ever just put the 5100's on the front to level out the truck ? I am not sure I want to mess to much with the ride. but would like a slightly larger tire and a level ride..
  2. Mar 17, 2015 at 11:04 AM
    Manwithoutaplan
    ID
    Yea i just installed a front 5100's adjusted for a guy and he is level. He did not mess with the clip at all.
  3. Mar 17, 2015 at 11:10 AM
    jakeda
    denver
    2015 dbl cab LB
    n/a
    what setting was the fronts set to to be level ?
  4. Mar 17, 2015 at 11:12 AM
    Manwithoutaplan
    ID
    Yes the clip is at lowest setting on the bilsteins. He purchased 5100's in the back and leaf pack he might have to adjust the front.
  5. Mar 17, 2015 at 11:19 AM
    TacoTakeover
    TacoTakeover Well-Known Member
    I have a 13 Sport and did 5100s on the front only with stock springs at the 1.75 setting and it sits perfectly level and no complaints.
  6. Mar 17, 2015 at 11:22 AM
    Pigpen
    Dan
    Northwest Montana
    My AC was super bro leaned at 1.75. Fortunately I have ride rite air bags, so I just pump them up to level as needed. This ate my stock shocks, but feels nice with the new N182s.
  7. Mar 17, 2015 at 11:36 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Second setting (.85) for 3 leaf OEM pack. Third setting (1.75) for 4 leaf OEM pack.
    Generally.
    Measure your own truck from center of hub to fender and see what your height difference is, then go with what makes sense for you. You can get more lift or less lift with these settings, FYI. They're ballpark figures.
  8. Mar 17, 2015 at 11:43 AM
    Pigpen
    Dan
    Northwest Montana
    ^^ this
    set at 1.75, I got closer to 2.25 with my V6 Access Cab. I lose half an inch when I put my winch on.
  9. Mar 17, 2015 at 11:45 AM
    T4RFTMFW
    I got 1.5" at the .85 setting myself.
  10. Mar 17, 2015 at 11:45 AM
    Manwithoutaplan
    ID
    how heavy is the winch?
  11. Mar 17, 2015 at 11:49 AM
    Pigpen
    Dan
    Northwest Montana
    never weighed it. It's a Warn x8000i with 3/8 wire rope on an external carrier. Maybe I don't lose a full half, but it's enough to notice just looking at the truck. My needle bearing hums like a mofo too when the winch is on :D
  12. Mar 17, 2015 at 12:07 PM
    jakeda
    denver
    2015 dbl cab LB
    n/a
    What's the part number for the ones the fir 12+ tacos
  13. Mar 17, 2015 at 12:08 PM
    Manwithoutaplan
    ID
    FYi the suspension from 05 to 15 is the same.
