5100s to level my sr5 help?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jasoncracer, Jan 28, 2016.
  1. Jan 28, 2016 at 1:49 PM
    jasoncracer
    jasoncracer [OP] Well-Known Member
    2016 Tacoma crew cab sr5
    Led light bar ,running boards etc
    I just measured from center of hub to fender on my sr5 I am 3/4'' higher in rear.i want to install 5100s in the front to level it out with stock coil I know there is 4 setting ones like ,87 of an inch second is 1.5'' what have you guys set your 5100s to level one of these trucks.
    also if you used 5100s whats max you went up and what block or leaf did you use in rear?
