5100s = true lift?
Discussion in 'Suspension' started by raycie, Mar 10, 2011.
  1. Mar 10, 2011 at 12:06 AM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Just curious if 5100s with stock springs at any setting is actually giving you a true lift or a little less..
    Reason..
    5100s@1.75 (stock trd sport springs) = 21.5 fender to center of wheel hub.
    5100s @0 884s (2 1/2 days old ) = 22.5 fender to center of wheel hub.
    So either the 5100s set at 1.75" wasn't a true 1.75 lift, or the initial lift on some 884s gave me 2.75" lift...
    Which makes more sense?
  2. Mar 10, 2011 at 4:24 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Easy answer if you measured the fender to hub before lifting.
    I would guess that the 884's will settle slightly.
  3. Mar 10, 2011 at 8:36 AM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Didn't take pre (any) lift measurements...
    Hence the question if anyone else knew....
  4. Mar 10, 2011 at 8:39 AM
    KPT
    09 Prerunner
    My billy's lifted my truck exactly 1.75"
  5. Mar 10, 2011 at 11:32 AM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Thanks.. So I guess 884s gave me 2.75" initially.. AWESOME.. I was looking for between 2" - just under 2.5".
    With the slight amount of settle, I should be right on target..
