5100's/TSB
Discussion in 'Suspension' started by 503TRD, Feb 9, 2011.
  1. Feb 9, 2011 at 10:50 PM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    I'm going to call tomorrow and see if the dealer will perform the rear leaf TSB, and if they will, I'm going to get Billy 5100's up front and set them at 1.75" or .85", whichever will level...Anyways, I have searched about the lean, and stuff, does every lift have this Taco lean? I've never noticed it, do I need the 1/4 spacer to level the lean out? Or may I not need it? And also, I don't need UCA's by setting the 5100s at 1.75" or .85 will I? How will my alignment be...All this more searching about the lean and alignment issues are making me second guess getting this lift done...Oh, and about how many inches will the total lift be (from stock height) after the 5100s and tsb
    Thanks. I did use search and read, but couldn't find my exact questions/concerns.
  2. Feb 9, 2011 at 11:17 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Lean: wouldn't hurt to get the driver side spacer. I'd assume all tacos have the same lean beings the battery, gas tank, and driver are all on the drivers side.
    Ucas- you'll be fine without new ucas. You don't REALLY need to worry about those till you lift around 3 inches. Alignment should be no prob at .85 or 1.75 setting.
    Pretty sure the tsb gives 1 inchish of lift. You'll get either .85 or 1.75 inches of lift up front, which either you choose. You should be able to find pictures of trucks at both settings.
    You really shouldn't hafta worry about many issues, probably none at all with that mild of a lift. It's definitaly worth it for the look your truck will obtain!
  3. Feb 9, 2011 at 11:32 PM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    Yeah I have like 2" Tuff Country spacer that leveled the front with the rear, but my rear rides likes crap an sags with weight in the bed, so I'm gonna get the TSB Leafs(hopefully) then get Bilstein's to level it again, getting rid of the spacer. But I shouldn't have to worry about any problems really? I could always get the setup all done, then if there is bad Taco lean I could order the 1/4 plate and get it installed, could I not?
  4. Feb 10, 2011 at 8:08 AM
    wolfdog2314
    Brush Prairie
    Good plan!
    Of course you can always do that. Get your 5100's on there. Get an alignment. See how it looks. And decide then if you want the small spacer or not.
  5. Feb 10, 2011 at 11:22 AM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    Alright great! Thanks a lot guys for the reassurance, I was starting to worry myself!
