5100's up front and TSB 4 pack in back
Discussion in '2nd Gen. Tacomas (2005-2015)' started by starwarsrosey, Aug 24, 2012.
  1. Aug 24, 2012 at 3:47 PM
    starwarsrosey
    starwarsrosey [OP] Well-Known Member
    Buffalo, NY
    17 Tacoma DCSB Limited
    Meso V4.0 Turn Signals Badges Blacked Out Blacked out foglight bezels
    Ok I have read a bunch of these on here but get confused. I have an 05 sr5 double cab. It has billies 5100's up front and TSB 4 pack in back. I also have air bags in back susp. When i buy new tires will I be able to fit 285/75/16? On my old dodge I had bfg at's 295/75/16 would these fit? Thanks for help but i get so confused with all the different posts on here.
  2. Aug 25, 2012 at 7:11 PM
    starwarsrosey
    Buffalo, NY
  3. Aug 25, 2012 at 7:14 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Any lift on the front?
    If so 1.75 need loads of trimming
    3 inch lift it will need some trimming to
    Either way you will be cutting to get your wheels to turn.
  4. Aug 25, 2012 at 7:21 PM
    starwarsrosey
    Buffalo, NY
    blackshirts^^^^ just the 5100s. they were on the truck when i bought it. the way it sits now looks like there is tons of room. i just get so messed up. people start talking about back spacing and all that. i was basically just looking to see if i could fit them with what i have on stock rims.
  5. Aug 25, 2012 at 7:22 PM
    starwarsrosey
    Buffalo, NY
    my avatar is the way it sits right now
  6. Aug 26, 2012 at 5:59 AM
    Blackshirts
    TX
    Stuff
    Either way you go 285s you will need to trim. I even know a couple guys who did a body mount chop just to get 285s to stop rubbing when the wheel is totally cranked.
    Can't imagine kind of trimming you would need to do with 295s but it could be done i suppose.
  7. Aug 26, 2012 at 6:33 AM
    rick
    rick `
    the plethora of information can be a bit overwhelming. To anwer your question. If you put 285s on stock rims you will need wheel spacers up front. I think most of the members here choose spidertrax. I don't think the 295s will fit. As far as backspacing is concerned that only comes into the equation if you get aftermarket rims. Hope this helps. And yes you will need to trim a little.
  8. Aug 26, 2012 at 6:08 PM
    starwarsrosey
    Buffalo, NY
    yes it does. but the next question is i guess to rick. any idea how much of a wheel space? oh and sweet avatar!!!!!!!!!!!!
  9. Aug 26, 2012 at 6:21 PM
    rick
    rick `
    1.25 i believe
  10. Aug 27, 2012 at 3:00 AM
    starwarsrosey
    Buffalo, NY
