5100's vs. Coilovers
Discussion in 'Suspension' started by DWreck, Aug 4, 2010.
  1. Aug 4, 2010 at 4:42 PM
    DWreck
    DWreck [OP] Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Diego came by to pick up a cb antenna bracket I made for his truck.
    While he was her I decided to snap a couple of shots.
    Diego; socal16 http://www.tacomaworld.com/forum/members/socal16.html
    08 TRD OR 4x4 Black
    Front; Icon coilovers
    Rear; TSB
    Tires; 265/75R16
    Derek; DWreck http://www.tacomaworld.com/forum/members/dwreck.html
    10 TRD OR 4x4 White
    Front; Bilstien 5100's set at 2.5"
    Rear; TSB and 5100's
    Tires; 265/70R16
    He sits about 1/2" higher from the tires being different. They both ride very nicely!
  2. Aug 4, 2010 at 4:55 PM
    DWreck
    Derek
    Las Vegas, NV
    bump
  3. Aug 4, 2010 at 5:15 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  4. Aug 4, 2010 at 5:17 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
  5. Aug 5, 2010 at 10:17 PM
    Gabex35
    Gabex35 Shinty Killer
    Gabe
    San Diego
    2014 4 Runner Trail Premium
    King OEM Performance Series with compression adjusters, Custom rear coils drom CSS, 22% Tint, Method Race NV's 17x8.5, 285/70-17 MTR's, AllPro welded Sliders, Cobra CB, Gobi stealth roof rack, Rigid 40" e series & duallys out back
    this is exactly what i've been looking for. Thank you
    So the only difference in height is attributable to the larger tires?
  6. Aug 6, 2010 at 4:17 AM
    DWreck
    Derek
    Las Vegas, NV
    Correct! However, he could also crank up his coilovers more. IMO, the ride is rough enough though and when off road there is not much "extension" before the travel is maxed out.
  7. Aug 6, 2010 at 5:21 AM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    OME 885x coils, 5100's set at 0. Deaver 2" AAL and 5100s out back. AFE Pro Dry S drop-in, BHLM, '10 sport grille.
    Man, there's a lot of Vegas presence on here!
    Nice trucks.
    Maybe you can answer a question for me that I'm having trouble sorting out? It sounds like with either coil, Bilstein adj, or a coilover front lift (all looking for 2.5") - I'm restricted to only about an inch of down travel - resulting in a rougher ride. What's the best way to maintain near factory ride quality and travel?
  8. Aug 6, 2010 at 4:42 PM
    DWreck
    Derek
    Las Vegas, NV
    Down travel is limited, I am not sure exactly how much. I guess longer shock extension would help. I do not have an issue with my 5100's. As far as the rear goes, do you have the TSB? It is a bit rougher but better as it is a truck, not a sedan, IMO. If stock ride is whished, blocks are good. They are my least favorite method but they work.
  9. Aug 6, 2010 at 5:38 PM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    I don't have the TSB and am not planning on going with a block rear. I'm fine with a little more rigid of a ride - I just don't want it to get like my Chevy was with the torsions adjusted... that sucked.
  10. Aug 6, 2010 at 7:38 PM
    Gabex35
    Gabe
    San Diego
    Don't mean to get off subject but seeing as how you have the exact set-up i'm contemplating....what do you think is the largest tire you could fit on there? (on stock rims)
  11. Aug 6, 2010 at 9:06 PM
    DWreck
    Derek
    Las Vegas, NV
    I had an 07 with a 3" spacer in the front and ran 285's....it rubbed but I beat the shit out of it and never had an issue with them tearing anything apart!
  12. Aug 6, 2010 at 9:07 PM
    DWreck
    Derek
    Las Vegas, NV
    I had a 97 Chevy 1500 with a Procomp 6"....Shitties truck I owned. Looked badass but between the harsh ride from the torsions and the front end needing replaced every 4 months....F that! Got my 07 Prerunner after that.
