5100's vs stock sport shocks ride comparison
Discussion in 'Suspension' started by TacoDawgfan, Dec 26, 2012.
  1. Dec 26, 2012 at 11:42 AM
    TacoDawgfan
    TacoDawgfan [OP] Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I'm hoping to pull the trigger on at least the front 5100's to level my truck soon. I'm torn between .85 and 1.75 with tsb, aal, or even a 1" block. I'm not an avid wheeler. I want to keep the ride as smooth as possible while achieving the look I want of leveling and even a slight lift (1.75). My wife already says my truck rides too ruff for her liking. :rolleyes: I think it rides great for a truck personally. I'm ok with a little more stiffness of a ride but don't want it too harsh and want to keep the wife happy also.
    I've read how people say 5100's ride better than stock. I've read that some chose to stay at .85 to avoid the stiffer ride. I've read that at .85 and 5100's all the way around it rides better. I've even read that it still does with a tsb or aal and 5100's. I've read that some where not happy after the rear leaf tsb, that it's too rough a ride.
    My question is how much rougher/stiffer a ride should I expect at .85 stock rear? And 1.75 with the tsb or aal?
    I know I'll probably get many opinions but I just want to ask so I can try to take it in as a whole to help me decide plus maybe other readers can use this thread to help also.
    Thanks!
  2. Dec 26, 2012 at 2:58 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Don't preload springs just for looks.
    Your wife is right.
    5100's without preloaded springs is pretty good, or so I thought until I got some real springs (Dakars)...now it rides fantastic.
  3. Dec 26, 2012 at 3:21 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    Putting any pre-load on coils=rougher ride. 5100's are a vast improvement over stock shocks. IMO putting a little pre-load on them is ok, they are still better then stock even with some pre-load. With that said 5100's set@1.75 was more firm than stock but In a good way. The rear spring tsb is not going to improve the comfort, it will provide a small amount of lift 1" +- but it's more for improved load carrying and towing. For the rear I would get a progressive aal to achieve lift.
  4. Dec 26, 2012 at 4:15 PM
    TacoDawgfan
    Georgia
    I am one that that likes to do things the right way. With that said, I can't afford new coils or a full out lift. And I think 5100's at 1.75 would be perfect for what I want. I may be happy at .85 but I have played with the floor jack and tape measure and really liked the look at about 1 3/4" if that is indeed what 1.75 equals out to. I just don't want to spend the $ for install at .85 and want to go up one more notch.
    As far as the rear I know I can do a 1" block for cheap. But there is where i'm torn. I would like to do the aal/tsb but I know that will stiffen it up. So I'm thinking doing a block, even though I know I'll get flamed on here for that. I just don't think a 1" block on the rear will hurt myself. I mean back in the day people used to run 4" and up on the rear. But I'm more trying to get an idea if I'll like the fronts at 1.75.
    I got some money for Christmas and have about enough to do the fronts, just maybe not for install. :notsure: So anyway I'm :goingcrazy: trying to decide. But I have time for that. Can't order them until Jan. 2nd on DSM anyway.
  5. Dec 26, 2012 at 6:09 PM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    Adding a 1" block will be fine. I've been running them w/tsb pack and have no complaints.
    My first setup was 5100's at 1.75(yes it's 1 3/4") and tsb pack. Personally I didn't mind the stiffer ride w/tsb but the 5100's may have helped.
  6. Dec 26, 2012 at 8:09 PM
    TacoDawgfan
    Georgia
    Here's some pics of my truck playing with the floor jack. Couldn't get the whole truck in since I was in the garage.
    .85
  7. Jan 2, 2013 at 10:18 PM
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Go 1.75" and keep the rear stock for now. If you don't throw a ton of crap in the bed you'll love it and it'll be level. If not add a 1" block. But I doubt you will want it. Im 1.75" in the front and love it. About to go higher 3.5" front and 2" rear.
  8. Jan 3, 2013 at 2:19 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    When I got my 5100's I wanted to figure out the correct level setting; as regardless of measurements, the front and back fender are shaped differently. So I had to check a truck that I knew was level. My boss' 2005, 5 lug came level stock. No fender flares, but that doesn't change the math. Going from center of hub to bottom of fender he had 50 cm (19.7") in the rear and 46 cm (18") up front.
    So all things being equal, there should be 1.7 inches of difference between the front and back in a level truck. So using my own past measurements of 20" up front and 22.5" in the rear, 1.75" would set me at dead near 100% level. This however won't take into account weight in the back, etc, so I went with the .85 setting.
    I also hear some say that the Off Road progressive coils don't offer as smooth a ride as the SR5/Sport linear coils. The OR coils do ride different even with the stock shock, but with just the .85 setting on the Billies, I am happy with the results.
    Getting the Billies on all four corners is the key to a firmer ride. For a truck with no rear sway bar, you can really notice the difference in cornering and highway ramps.
    Hope this helps.
    Frank
