5100s vs TRD Sport Shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wackym8, Apr 24, 2025.
  1. Apr 24, 2025 at 10:48 AM
    wackym8
    wackym8 [OP] Member
    2016 Tacoma TRD Sport DCSB
    My 2016 TRD Sport has 68k miles and i am thinking about swapping to bilstein 5100s on all 4 corners with 3rd notch in the front for a about 1" lift. Just wondering how different the ride quality is between the sport shocks and the 5100. I know i will lose the sporty, on-road feel. I am looking to improve performance over bumps and for light off roading. Thanks.
    Tcoma16 and Tocamo like this.
  2. Apr 24, 2025 at 11:36 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    5100 on the middle notch and don’t look back.
    WHITE_SR5 and TXpro4X4 like this.
  3. Apr 24, 2025 at 11:39 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    shock feel is personal preference, but given the application, I would say you are looking the right direction. You may consider a new rear leaf pack rather than blocks. The OE leaf pack is flimsy AF when doing any towing, or even groceries.
    blu92in99 and killthehippies like this.
  4. Apr 24, 2025 at 11:45 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    I vote for 5100s
    TXpro4X4 likes this.
  5. Apr 24, 2025 at 11:50 AM
    Bishop84
    Bishop84 Well-Known Member
    Do it, and mid notch actually helps reduce brake dive. They are way better than hitachi sport shocks
    Canadian Caber and blu92in99 like this.
  6. Apr 24, 2025 at 1:22 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Night & day with bonus of no more oem brake dive. If your only doing 1" up front, you wont need a block, nor AAD in the rear. Your truck will look lifted, "level" and handle like a champ.
    Canadian Caber likes this.
  7. Apr 24, 2025 at 3:16 PM
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    5100s are much better than the stock sport shocks. A noticeable difference in the drive. 100% worth it.
    Tcoma16 likes this.
  8. Apr 24, 2025 at 8:08 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I swapped out my Sport solid steel rods that Toyota calls shocks for Eibach Pro-Truck coil overs. They would be similar to the Bilstein shock to my understanding. I found this to be a very good improvement to the ride quality of the truck. This is my experience and your experience might not be the same. I liked the change.
    Tocamo likes this.
  9. Apr 24, 2025 at 8:14 PM
    RunnerBlue4
    RunnerBlue4 Active Member
    Mark
    I have a 2017 Tacoma Sport AC with 47,000 miles. It will be loaded with about 400 lbs for camping. The rest of the time the bed will be empty as a daily driver. I'm okay with the ride know with the bed empty. I'm thinking of going with a set of 5100's. Should I be considering a rear leaf pack? I was thinking of the Icon RXT pack. Would that be a good compromise for empty bed daily driving and loaded bed camping? Are there other leaf spring I should consider?
  10. Apr 24, 2025 at 8:17 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I love my Bilstein 5100’s. They’re fantastic for light-medium off roading and still being good on the road.
    Tcoma16 and Canadian Caber like this.
  11. Apr 24, 2025 at 8:57 PM
    Tcoma16
    Tcoma16 Galatians 2:20
    California
    2016 TRD Sport
    I got 5100’s about 2 week ago for my TRD sport. A noticeable difference for sure. I would recommend :thumbsup:
  12. Apr 24, 2025 at 9:07 PM
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
    The Sport shocks are inherently stiffer by design. Go with the 5100's.
    Tcoma16 likes this.
  13. Apr 24, 2025 at 10:03 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    If you decide to raise the rear the oem 1in or .5in blocks can be had for cheap(mine were something like $16 from my local dealer). If you go with the 1in blocks dont get the 5100s though get the 5125s that have a compressed length that is 1in longer (5125s are available in several lengths). Unlike the stock length shocks they let you use the full travel of the oem springs.
  14. Apr 25, 2025 at 4:19 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Just my opinion, since I rarely load my truck, but would be concerned with the stiff ride when it's empty. 400 lbs is nuthin'.
  15. Apr 25, 2025 at 4:27 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    What length 5125's would you need for 2" rear blocks? My 19 Sport has a 2x2 lift. I'm assuming since the front 5100's are adjustable, I could clip them for a 2" lift, and keep my same height of my 2x2? Ski
  16. Apr 25, 2025 at 5:36 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    I cringe everytime I see a dude's rear axle hanging 2" below the leafs.
    Get new leaf packs ideally, or add-a-leafs, for more than 1/2" to 1" of rear lift.
  17. Apr 25, 2025 at 10:02 AM
    Mach
    Personally I would remove the 2in rear block and throw the oem 1in in. 2in blocks have way too much axle wrap.
    That said bilstein makes some 5125s with a compressed length of 16.01. They will allow full travel of the spring but you probably need longer brake lines at the axle and a bracket to reposition the e-brake cables as well to not break things as proper length shocks will allow more down travel than shorter ones. You may still run into vibration issues and likely wear out your springs and u joints withh the 2 in block as well as the ride quality problems from the axle wrap. The longer shock will help avoid the roughness from a too short shock hitting full extension though.
    5125s come with the wrong bushings for our trucks. Either the right lower bushings need to be ordered or they need to be cut down (both the steel sleeve and the rubber bushing)
  18. Apr 26, 2025 at 6:38 PM
    pultaco12
    pultaco12 Active Member
    2020 TRD OR 4x4 DCSB
    if you go 3rd notch on the 5100s, would the needle bearing eventually go bad and need an ecgs replacement?
  19. Apr 26, 2025 at 6:39 PM
    Bishop84
    No only spacers cause this issue or larger coil overs. I've never had to install the bushing on any 5100/TRD lift.
    bryan83taco likes this.
