5100's w/ AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tencrawler, Jan 30, 2011.
  1. Jan 30, 2011 at 8:54 AM
    tencrawler
    tencrawler [OP] I'm a lover not an expert
    Wes
    Petaluma
    1985 Pickup 4x4 SCLB 22R 5SPD Manual
    Only 55K Original Miles in Spring of 2018
    I just purchased my 5100s and a set of Fat Bob's Garage AAL. My truck sits pretty low with the tired (70k)non TBS leaf springs. With 1.5 to 2" of lift from AAL what should the 5100s be set at to achieve a level stance or slightly nose down (in case AAL don't give me enough lift)? Your opinions are all greatly appreciated.
  2. Jan 30, 2011 at 9:17 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have 2.5 up front and a 2" aal in rear...
    but i carry some weight in the back
  3. Jan 30, 2011 at 10:11 AM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    I have mine at 1.75 with a 1 1/2 AAL in the rear. It sits 1/2 ass high . Check out my gallery.
  4. Jan 30, 2011 at 10:15 AM
    tencrawler
    Wes
    Petaluma
    I carry a toolbox with tools in the back, and I'm only hoping for 1.5" of lift from the AAL. I think I will staTy out with 1.75" and go from there. Eibachs and Dealers when I'm ready for new tires. Thanks for the input.
