5100s w/ Eibachs: do I need rear lift?
Discussion in 'Suspension' started by KingMoo, Sep 28, 2011.
  1. Sep 28, 2011 at 1:34 PM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    I dont have a rear TSB and I can't get one. with the 1.6" lift will I have a major bro lean? Also, if I install an AAL later will I need another alignment?
  2. Sep 28, 2011 at 2:19 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Depends on how high the rear is currently compared to the front. Measure from hub centre to the fender arch front/ rear on both sides and let us know. Keep in mind that the rear arch is 0.75" higher than the front one by design, so you'll want to account for that.
  3. Sep 28, 2011 at 2:19 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    You will not have a major bro lean at all, I have the Eibachs with my 5100's at .85" lift and a 1.5" leaf pack and I am level. You will probably be barely nose high.
  4. Sep 28, 2011 at 5:01 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    you going to sit front high without tsb, level with tsb, and factory rake with 1.5 aal on tsb or 2" aal on non tsb. If you have the half spacers with the rear aal than you will be level and close to 3" lift.
    this is going off my truck.
    im level with .85 setup with 1/2 spacers on both sides and 1.5" aal with tsb
