5100's with 1.75 lift and now caster at 1.8
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2013taco, Mar 17, 2013.
  1. Mar 17, 2013 at 6:01 PM
    2013taco
    2013taco [OP] Active Member
    dfw area
    2013 Prerunner trd
    5100's shocks, 884x, black trd tt wheels, airlift rear air bags, custom rear bumper, light racing uca.
    Just put the bilstein 5100 shocks on all way around and set front ones to 1.75 lift, after alignment they got camber and toe to 0 and caster is at 1.8 on both sides. Still rides good but wonder if went ahead and replace uca would make that big of difference. I used stock springs also. thanks.
  2. Mar 17, 2013 at 6:05 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    If your happy with how it drives then there is no need for UCAs. Aftermarket UCAs will add caster which will help with wondering at high speed.
  3. Mar 17, 2013 at 6:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    it also helps with wandering.
  4. Mar 17, 2013 at 6:15 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I wander what that means
  5. Mar 17, 2013 at 6:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The OEM TX Baja package lifts 2.0" with stock UCAs. You are fine.
    Replacing UCAs takes 2x-3x as long as replacing the shock, not worth the effort IMO for just a 1.75" lift.
  6. Mar 17, 2013 at 6:36 PM
    2013taco
    dfw area
    2013 Prerunner trd
    ok still feels good just, not quite as good as stock did. Will leave like they are for now and can always upgrade if needed. just did not want to mess anything up or cause parts to wear faster than normal. I drive about 125 miles a day. thanks.
  7. Mar 17, 2013 at 6:44 PM
    medic2230
    Murph
    Bama! Roll Tide
    Well if it doesn't feel as good as you want and drive that much you might want to get them.
  8. Mar 17, 2013 at 6:48 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    ^^^this...and the install was a lot easier and faster than doing the lift.
  9. Mar 17, 2013 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :confused: Takes about 45 mins to do both sides. Nothing to it.
  10. Mar 17, 2013 at 6:56 PM
    2013taco
    dfw area
    2013 Prerunner trd
    your right looks like the uca are alot easier than the lift. Should not be hard at all to install. I will use this truck for 95% highway driving the light racing arms looks to be the best price and if not offroading should hold up pretty good. Only negitive i have read is that they loose alignmet on uca pretty easy. Anyone that does mostly dirt road and highway driving haveing any problems with alignmet staying in? thanks.
  11. Mar 17, 2013 at 7:00 PM
    medic2230
    Murph
    Bama! Roll Tide
    Mine have been dead on for the last year since I put them on. No problems at all. They will only take about 45 minutes to install. I know, I installed my lift myself. I drive about 80 miles round trip to work and take this truck everywhere and wherever I might like to venture.
  12. Mar 17, 2013 at 7:04 PM
    KenLyns
    Belly of the Beast
    I had to cut the UCA bolt (and installed new ones in the opposite direction). On my truck, just bending the inner fender with Channel Lock pliers wasn't enough for the bolt to clear.
    Out of curiosity I called a Toyota dealer. Their quoted labor time for UCA replacement was 4 hours.
  13. Mar 17, 2013 at 7:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah....well, they quote more time, for less work.
  14. Mar 17, 2013 at 7:10 PM
    medic2230
    Murph
    Bama! Roll Tide
    I bent my fender out of the way and removed the battery. Used the same bolts and put them back in the same way. Toyota gets paid by what the book says not by how long it actually takes to do it.
  15. Apr 7, 2013 at 8:33 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    What brand of uca is recommended ?
  16. Apr 7, 2013 at 8:55 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I will be getting Light Racing. They're on the lower end pricewise and there are other options.
  17. Apr 7, 2013 at 8:57 PM
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    the tx baja comes pre lifted from toyota!?!?!?! damnnnnnnnn, wish i would have known that now...... maybe in 2 years i can swap out to that, and hopefully, it has the 5.7 tundra motor option with a 6 speed, and atleast 4.10's rears (i can hope right?)
  18. Apr 8, 2013 at 4:46 AM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    I was looking at camburg and they have a max of wheel with and ofset that can be use. Do you know if de LR have any restrictions?
  19. Apr 8, 2013 at 5:26 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    yea i would like to know also. havent had any problems out of mine.
