5100's with 884 Coils
Discussion in 'Suspension' started by ATHiker, Jul 6, 2013.
  1. Jul 6, 2013 at 8:24 AM
    ATHiker
    ATHiker [OP] Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    I have a 2013 DCSB TRD Sport 4x4 and am adding 5100's and AAL. My plan is to set the front 5100's at the 1.75 setting. If I go with the 884 coils and set the 5100's at 0,with this give the same lift as the 5100's set at 1.75 with the stock coils? Will I notice a significant ride improvement by going with the 884's with the 5100's set at 0?
  2. Jul 6, 2013 at 2:41 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    885 are the recommended coils for a double cab. I got about 2.5" of lift from them with the OME shocks. Not sure what the 5100s will net you. You should see a decent ride improvement using the OME coils because you won't be pre-loading the spring.
  3. Jul 6, 2013 at 5:32 PM
    ATHiker
    Tom
    Tennessee
    Thanks for the reply. I think I want to keep the lift 2" or less.
  4. Jul 6, 2013 at 5:34 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    X2 ^
    I'm running 5100s and 885s and am at almost 3"...but I have a PreRunner so you'll be at 2.5" ish
    jross20 likes this.
  5. Jul 6, 2013 at 6:49 PM
    ATHiker
    Tom
    Tennessee
    Sounds like the 884's will give me about the same lift as the 5100's set at 1.75" with stock coils.
  6. Jul 6, 2013 at 6:51 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Maybe a little more based on what i have seen others get. Should be around 2"
  7. Jul 6, 2013 at 6:54 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I have a 12' Prerunner and 5100s and 884 coils gave me 2". You have a 4x4 so you should be a little lower, 1.75-2". 884s will give you a better ride than 5100s at 1.75 because you're not pre-loading the coils.
  8. Jul 7, 2013 at 9:44 AM
    ATHiker
    Tom
    Tennessee
    One more question. Should I go with the OME 884's or Elbach coils. I think the 884"s will give me just a little more lift. Otherwise, would there be any difference in ride / performance?
  9. Jul 7, 2013 at 9:57 AM
    bjboucher
    Brad
    San Antonio, Texas
    From what i've read, the Eibachs will be stiffer. Especially over the 884s.
  10. Jul 7, 2013 at 10:01 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    884's spring rate is 590 and Eibach's spring rate is 620. Higher the number, stiffer it is.
  11. Jul 7, 2013 at 10:08 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I wouldn't over-think this. Either eibachs or 884s will work fine and provide you roughly 2" of lift. I love how folks are predicting how much lift you'll get within 1/4" :rolleyes: It's not that exact of a science and depends on how much optional equipment plus add-on-junk is in your truck, not to mention how worn your original shocks and springs were before you made the swap.
    Anyhow, as far as the ride goes: "Better" is a personal thing. The stiffer springs will provide a more "firm" or "connected" ride. They will definitely ride better over harsh large bumps that caused the original suspension to bottom out and hit the bumpstops. But over ordinary expansion joints on the freeway, the softer factory springs will probably feel milder.
  12. Jul 7, 2013 at 10:45 AM
    ATHiker
    Tom
    Tennessee
    I have read where OEM coils are not recommended for use with the 5100's, but as I understand it, many are using them. That is why I am also considering the Elbachs. I already have the 5100's.
  13. Jul 7, 2013 at 10:48 AM
    ATHiker
    Tom
    Tennessee
    Can I just calculate the percent difference between 590 and 620 and say that the Elbach's are 5% stiffer?
  14. Jul 7, 2013 at 11:26 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    As Steve said, every truck is different when it comes to exact lift measurements. Stiffness IS a personal thing. I know some guys who prefer stiffer rides because it's a "truck" and I know some guys who prefer softer rides because they're use to driving "luxury" cars.
    Is 5% THAT much of a difference to you? Only you can determine that. In the end, you can't go wrong with either ones. Both options are better than spacers and blocks. :)
  15. Jul 7, 2013 at 4:04 PM
    ATHiker
    Tom
    Tennessee
    Thanks for all the replys
  16. Jul 8, 2013 at 1:35 PM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    '13 MGM DCSB 4x4 TRD sport, Tow and Entune
    Tonnopro tonneau cover, Weathertech digital fit mats, Magnaflow 18" muffler with black exhaust tip, blacked out badges/emblems, Passport 9500ix, Pop & Lock PL8521, EZdown tailgate mod, 17" KMC XD addicts, 265/70/17 Nitto Terra Grapplers, OME 884 springs, Bilstein 5100's at zero, BHLM, FX-R retrofit, 80mm and 110mm morimoto rgb halo's with Bluetooth control, Raptor style led's in grill, LED's for dome, maps, reverse, license plate, parking lights, switchback DTRL's, ultra-gauge, Kenwood DNX690HD, Hertz HDP4, Hertz HSK165's, Memphis 12" in custom box, Black/Grey Roadwire leather kit with seat heaters, cool white interior led's from oznium.com, 20" AVEC dual row light bar in lower bumper, 19" AVEC single row light bar in grill,
    I also have a 2013 DC SB sport 4x4. I went with the 884 springs and 5100's and got right at 2" of lift in the front. I did use the toytec 1/4" spacer on the driver side as well. Ride doesn't really feel any different to me vs. stock ride. I am very happy with the look. I also just moved up to 265/70/17 terra grapplers and have a tiny bit of rubbing on the mud guard. There is a little bump area inside the wheel well where the guard attaches and that is where it is rubbing. Am going to hit it with a heat gun and try to flatten it out and that should solve the issue.
  17. Jul 8, 2013 at 3:10 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Parboy,
    What setting did you have the 5100's set to? Did you do anything to your rear end?:rolleyes:
  18. Jul 9, 2013 at 6:58 AM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    5100's are set at zero, just using the 884's to get the lift in front. I just used 5100's in the rear as well, straight swap out of the stock shocks. Just wanted to level the truck out. I don't have any updated pics in my profile, but will add some soon to show the new look.
  19. Jul 9, 2013 at 8:57 AM
    dand
    Dan
    Newport News VA
    thanks, this sounds like what I want to do.
  20. Jul 11, 2013 at 6:00 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Sorry to jack but , Is it possible to get more lift from a Bilstein 5100/ OME 885 combo ? Does it have to be at 0? I am looking for 3" up front ? I have a 2011 DC 4x4.
    I also wouldn't mind using Eibach springs if I can get more lift with the Bilstein/Eibach combo.
