5100s with aftermarket coils
Discussion in 'Suspension' started by kram, Nov 23, 2010.
  1. Nov 23, 2010 at 12:01 PM
    kram
    kram [OP] Well-Known Member
    Squamish, British Columbia
    09 TRD Offroad Access Cab 6spd MGM
    URD Short Shifter TSB Leaf Pack, Bilstein 5100s front (1.75") and rear. 285/70/17 Duratrac on Rhino Sidewinders. Weathertech Digifit Floormats
    First of all, sorry to start yet another 5100 thread, but I've spent 2 hours looking and searching and I still am unsure what to do.
    I have ordered 5100's front and rear and intend to install them myself. I'm going to buy a spring compressor since that is cheaper than paying for someone to do it for me and at least I'll learn something.
    I'm confused on the issue of aftermarket springs with the front shocks. On the sticky thread it says "Bilstien 5100's This is a great affordable lift kit. These replacement shocks are great to add a few inches to the front of your Tacoma, it is adjustable and have a slightly better valving system than the stock shocks that come with the Tacoma's. (But please take note NO One recommends it to be used in conjunction with after market coils) This may result in damage of your suspension components."
    But it seems like a lot of people are doing this. And I wonder if it's better to run the 5100s on the first or 2nd setting with a firmer coil rather than using more preload. Surely a spring works better with less preload doesn't it?
    If I was to go this route, I want to lift my truck as high as I can without needing new UCAs, so I was going to lift 2.5in. Is there a coil that can do this either on setting one or two on the 5100's? And would this in fact give a better ride than using the stock spring (TRD OR) set at 2.5? Anyone have any recommendations for brands/models?
    Also, do I need to do a diff drop or anything else at 2.5?
  2. Nov 23, 2010 at 1:34 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I replied to your PM. I think the 5100's on the 0.85 setting with the Eibach's is a great set up. I don't think having a shop compress/ install the springs on the 5100's would run you much $...I had a local shop do if for a case of beer. The eibach's are fine on the 0.85 setting, I phoned eibach, and Toytec and both said it was fine (except one guy I talked to at Toytec early on...he disagreed, but I phoned a week later and it was fine?!) Toytec even sells this as a kit and say's either at 0, or 0.85 depending on how much lift you want. I think the concern about different springs is more for the OME ones which are better suited with their shocks. Hope this helps.
  3. Nov 23, 2010 at 1:58 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have OME 885's on my 5100's at 0" height. Everythings okay so far.:cool:
  4. Nov 23, 2010 at 2:53 PM
    Fabulous
    Fabian
    Calgary, AB
    Yeah, I don't think it's a problem either way. I was originally toying with the 884/ 885's but they guy I spoke to at Toytec completly shat on the idea...
  5. Nov 23, 2010 at 3:08 PM
    spark4
    spark4 Well-Known Member
    So Cal
    2018 Tacoma TRD OR 4x4 Cement
    Bilstein 6100/5160, Ray 10's, 5.29, KDMax Tuned
    I run 885 @ 0 on my 5100's. No problems. Rides great. Ride is what I was most concerned with. Didn't want it to be stiff. A little stiffer than stock. Def. better dampening over speed bumps etc. But I think I got more than 2.5". A little under 3" after it settled. I also chose to run camburg ball joint UCA's.
  6. Nov 23, 2010 at 5:58 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It's fine to run aftermarket coils with the billy's, as long as the combination of the two don't lift more than 2.5". That's all the lift that the shocks were designed to accommodate.
    Running the billy's at 0.85 with the 1.6" eibach springs won't affect the shock any differently than if you were running stock coils on the 2.5" setting.
    They just don't want people running billy's at 2.5" with some OME 885's for 5.5" of lift, for example. The shocks would have basically no travel left.
  7. Nov 23, 2010 at 6:13 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've got the Eibach,s with 5100's set to "0". Great ride, no problems with vibes. I'm sure I could have gone to the .85 setting with no problems, and I might do that when I upgrade to 265/75/16's from the stock Dunlop junkers.
  8. Nov 23, 2010 at 10:10 PM
    kram
    Thanks for the input guys, but I think I'm doing to stick with the stock spring. Seems like that's what most people are doing and for the most part they are all pretty happy with the results.
