5100's with custom spacer
Discussion in 'Suspension' started by adamw, Sep 19, 2011.
  1. Sep 19, 2011 at 11:30 PM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    I have my fronts set at 1.75 with the rear stock and it sits level. I was looking into getting the icon 1.5" leaf pack and bumping the front up to the 2.5 setting...but will that be high enough in front or will it end up looking like the factory rake again? So what i'm wondering is that if I machine a 1/4 in thick ring that goes in between the spring and the spring seat is that basically the same as a 1/4 top plate spacer like the ones you would use to adjust your lean? any input would be greatly appreciated. Thanks
  2. Sep 20, 2011 at 9:23 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    2.5" up front and 1.5" in the back will level the truck, no rake.
    You could machine a thin top plate spacer if you want, to go up to 3" in the front. Toytec sells them for around $20.
  3. Sep 20, 2011 at 8:06 PM
    adamw
    sunnyvale, CA
    okay cool. do you have any experience with the icon leaf pack? how is the ride compared to stock? I dont really want to do the aal and def not blocks and I dont want to go any higher then 1.5 in the rear
  4. Sep 20, 2011 at 11:28 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    For the sake of god, do the leaf pack. :)
    I'll help you install the leafs! or next mod day we all can help ya!
    I hate AAL's...I've done 2 sets in my life and I hate them.:mad:
  5. Sep 26, 2011 at 10:02 PM
    adamw
    sunnyvale, CA
    sweet that'd be awesome ill try to come up with some funds by the next mod day and we could throw those one!
