5100's with OME 885 set @ 0 gives close to 2.5 inches of lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bishop2Queens6, Dec 7, 2015.
  1. Dec 7, 2015 at 7:15 PM
    Bishop2Queens6
    Bishop2Queens6 [OP] Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I installed my 5100's with OME 885 set @ 0 on my 2009 DCSB and it gave me close to 2.5 inches of lift. Bottom of my fender to the ground is now 37", stock it was 34.625."
    My question:
    -How much setting should I expect?
    -How long will it take?
    Other observations:
    Install took about 3 hrs, and I definitely needed a second set of hands helping to push down on the LCA with a cheater bar so I can have clearance to fit the 5100's with the 885's. I didn't remove the tie rod, but I was able to wiggle the coilover into it position, got a couple scratches on the spring but I don't mind those.
    Electric 1/2 inch impact helped a lot for lug nuts and the bottom shock bolt. Plus having deep well impact sockets. Crows feet on the torque wrench helped immensely in torquing down the top shock bolts.
    I purchased this spring compressor last friday to swap coils on my 5100's for about $90
    http://www.amazon.com/Goplus®-MacPh...1449544300&sr=1-15&keywords=spring+compressor
    I felt 100% comfortable using this spring compressor. No doubt in my mind for my safety. Very easily compressed the 885 coil to mount in on the strut.
    I removed my sway bar, and the truck feels like it rides stiffer than when it had it on.
    I am taking it to an alignment shop tomorrow morning, hopefully, I can get close to desired without having to get aftermarket UCA's.
  2. Dec 7, 2015 at 7:16 PM
    gracianoh
    gracianoh Well-Known Member
    06 1e7 access cab 4x4
    What size tires ? Anything in the rear?
  3. Dec 7, 2015 at 7:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Thats right
  4. Dec 7, 2015 at 7:22 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Tire size 265/75/16
    In the rear is the TSB 4 leaf pack with 5100's also
  5. Dec 7, 2015 at 7:22 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    I won't see any settling?
  6. Dec 7, 2015 at 7:25 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not really. 1/4 inch maybe. 885s are 2.5" coils.
  7. Dec 7, 2015 at 7:28 PM
    OZ-T
    Peter North
    British Columbia
    Probably not much
  8. Dec 7, 2015 at 7:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    shoulda just undone the lower ball joint from the spindle, marked then loosened the lower control arm bolts and dropped the spring n shock right out.
    No need for a spring compressor n MUCH easier. I can have a full shock n spring out and re-assembled in maybe 20 min per side.
  9. Dec 7, 2015 at 7:48 PM
    WoodsEdt
    WoodsEdt Member
    Tyler
    Missoula, MT
    2020 OR
    Arb bumper Snugtop topper Spacer lift :( Customer drawer system
    sub, will be doing the same set up once it comes in the mail.
  10. Dec 8, 2015 at 10:04 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Does that mean that 884's are 2"? And what's the difference between the 884 and the 884x?
  11. Dec 8, 2015 at 10:16 AM
    T4RFTMFW
    1.75-2". There is an OME spec sheet link that floats around and has everything you could ask for. Try The Google for that.
    X denotes a revised coil that is less prone to sag.
    884s haven't been manufactured in a while. All new coils will be X models.
  12. Dec 8, 2015 at 10:27 AM
    iK0NiK
    West
    Columbus, GA
    Thanks bud.
  13. Dec 8, 2015 at 10:29 AM
    T4RFTMFW
  14. Dec 8, 2015 at 10:44 AM
    iK0NiK
    West
    Columbus, GA
