5100's with OME 885's and Rear AAL (PICS)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sandyTrd87, Jan 2, 2016.
  1. Jan 25, 2016 at 8:46 AM
    #101
    Buddha717
    Buddha717 Well-Known Member
    Ron
    Harrisburg, PA
    2016 Inferno Tacoma TRD sport DCLB PTJBL
    Mine are -12 offset which gives 4.5 inch backspace. This is ideal
  2. Jan 25, 2016 at 9:01 AM
    #102
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    can't seems to locate Method's at 17" with -12 offset and 4.5" backspace
  3. Jan 25, 2016 at 9:06 AM
    #103
    Buddha717
    Ron
    Harrisburg, PA
    Sorry mine are 18's. The 17's will be 4.75 backspace with 00 setback.
  4. Jan 25, 2016 at 9:10 AM
    #104
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    aha.....gotcha
    need to re-read the wheel specs on how to read wheel specs.....god I confused myself....haha
  5. Jan 25, 2016 at 5:50 PM
    #105
    Pato Loco
    Pato Loco Well-Known Member
    There is only one size offset in the 17" NV's. Check their page or tire rack.com has them too I think. I think one measurement is 4.5 and one is 0. I think they are tucked perfect. Sticking out barely about even at top, and not tucked in at all but not chicano loco.
    I did not use the diff drop.
  6. Jan 28, 2016 at 6:45 AM
    #106
    Rylandport
    Rylandport Active Member
    2016 White DCSB TRDOR 4x4
    Ok, so I have a 16 TRDOR 4x4 and I'm looking at this same lift. 5100's all the way around with 885's and an AAL in the back. I'm wanting this same turnout as sandytrd87's sport has. And I'm wanting to keep the 5100's set at 0 just because I don't want to load up the shocks if I don't have to. Has onyone does this same lift with a 4x4? And how much with the extra weight of it being a 4x4 really affect the 885's? Worst comes to worst I could bump up to .85 and get what I'm looking for. I'm wanting a 2.25- 2.50 inch lift, no more. I'm trying to stay away from getting new UCA's. Thanks.
  7. Jan 28, 2016 at 7:08 AM
    #107
    Buddha717
    Ron
    Harrisburg, PA
    I think 885 set to 0 will give you 2 and a nice ride. I think 885 set to .85 will give you 2.5. Call over to Headstrongoffroad.com and they will give you the best combo. Thats what I did.
  8. Jan 28, 2016 at 7:25 AM
    #108
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    Go with 887s. Same spring rate as the 885s but they are slightly taller.
    61ragtop likes this.
  9. Jan 28, 2016 at 7:27 AM
    #109
    Buddha717
    Ron
    Harrisburg, PA
    I agree. That's what I have
  10. Jan 28, 2016 at 8:03 AM
    #110
    Rylandport
    Will they still keep my in the range of running my stock UCA's?
  11. Jan 28, 2016 at 8:03 AM
    #111
    Rylandport
    Do you have pictures or link to thread?
  12. Jan 28, 2016 at 8:17 AM
    #112
    Buddha717
    Ron
    Harrisburg, PA
    read through this thread. I think it has a lot of info. Also ask @ridez. I copied my set up from him. Call Marie at headstrongofroad.com and she will answer all your questions. It's the easiest thing to do to get it right.
  13. Jan 28, 2016 at 8:36 AM
    #113
    Rylandport
    O
    Ok, thanks a lot!
  14. Jan 28, 2016 at 9:48 AM
    #114
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    I have 5100s at .85 plus 887s from Marie at @HeadStrong Off-Road. We're thinking that we'll be ok without UCAs. My truck is a couple of days out, so I'll re-update once it's in and the kit is put on.
    HeadStrong Off-Road likes this.
  15. Jan 28, 2016 at 9:52 AM
    #115
    Rylandport
    Yes, please do!
  16. Jan 28, 2016 at 10:17 AM
    #116
    ScottyR
    Vancouver BC
    2016 DCLB TRD Sport
    If you want to go 2-3" I would get UCAs.
  17. Jan 28, 2016 at 10:57 AM
    #117
    beenjammin
    beenjammin Well-Known Member
    Auburn, AL
    2016 TRD 4x4 ORDCSB
    Is went with 5100 at .85 in front and ome in the rear. It sits about .5" higher in the front. I was going to have a 1" spacer put in the rear. Is the 887 a better option? I can't take the front being higher. People tell me it's not noticeable but it is an eye sore to me.
  18. Jan 28, 2016 at 10:58 AM
    #118
    Rylandport
    What are the problems with stock UCA's other than possible alignment problems? Will they end up hitting the coils when extended?
  19. Jan 28, 2016 at 11:47 AM
    #119
    Buddha717
    Ron
    Harrisburg, PA
    You may or may not have some rubbing issues but the UCA will help with allowing the alignment more room. I've heard of guys not running UCA and within specs for alignment but they have wandering issues while on the highway. 2.5-3 inches you are pushing the limit. Remember the Gen 3 already gives you a inch.
    sandyTrd87[OP] likes this.
  20. Jan 28, 2016 at 12:30 PM
    #120
    Rylandport
    I'm wanting to run my stock trd 16" wheels. Would I be better running a 265/75 16 or 285/75 16?
