5100's with OME885 question.
Discussion in 'Suspension' started by ryanr623, Oct 3, 2012.
  1. Oct 3, 2012 at 7:05 AM
    ryanr623
    ryanr623 [OP] Well-Known Member
    I have OME 885's with wheelers top plate 1/2" spacer in the front. And toytec AAL in the rear. I want to add another inch to the front to level it out, so i was all set to order 5100's....UNTIL I saw that toytec reccomends these set at 0 if used with aftermarket coil lifts. Whats the reasoning?
    CV angle? I would do the diff drop since I dont offroad seriously.
    Needle Bearing Vibration? I'll be doing the east coast gear fix.
    Alignment problems?
    Anyone know?
  2. Oct 3, 2012 at 7:08 AM
    TRON_
    TRON_ The Game Has Changed
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    IG: st3f3ns OverlandBound1235 R.I.P. Rinzler
    On my phone at the moment so bear with me, but i run my 5100s at.85 setting with the 885s no problem, its just not recomended since youre preloading the springs. Little stiffer but got the lift i wanted
  3. Oct 3, 2012 at 7:10 AM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    2000 4runner
    The OME coils are pretty strong when compared to stock or even eibach. My guess is that the 5100 isn't designed to handle that much pressure. I run my 885's with the 5100's at zero and wouldn't mind knowing the actual answer myself. sub'd.
  4. Oct 3, 2012 at 7:13 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod, Kobalt tool box, Bulldog Keyless entry, Sportsman max-4 seat covers, modded EL Bazooka basstube, Friends of Coal sticker and license plate, Green Hooks, Green Emblems, Green LED sony radio, Green shiftknob.
    i know im a first gen, but the main reason is the CV's cant hold the height of it, even with a diff drop its not low enough. thats our reason at least.
  5. Oct 3, 2012 at 7:19 AM
    ryanr623
    The strut top spacer does not preload the springs. Do you have the diff drop? How long have you been running that setup?
  6. Oct 3, 2012 at 1:44 PM
    hopper344
    hopper344 Active Member
    07 TRD Offroad Double Cab
    Shouldnt the front be leveled out, the 885 with top spacer should give about 3" lift or am I wrong?
  7. Oct 3, 2012 at 2:26 PM
    rockgecko03
    Ben
    Rockwall, TX
    2000 4runner
    Correct. He was talking about preloading the spring by running the 5100 at .85.
    I only got about 2"-ish of lift with the 885's with 5100's at zero. I have the lean spacer on the drivers side but no other top spacers.
  8. Oct 3, 2012 at 2:38 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    What shocks are you using now with the 885 and spacer? how much rake do you have now with your current set up?
  9. Oct 3, 2012 at 4:02 PM
    ryanr623
    Gotcha, I thought he meant I was already pre loading
    Trd off road factory bilsteins. I think i'm going to to the ecg vibration fix, diff drop and set 5100's at 1". I can always adjust them down, and if I cant align I'll just buy new uca's. love my Tacoma, just wish it didn't cause so many problems lifting it a mere three inches. My dad had a dodge ram, with 3" coil spacers and a rear leaf block (no I didn't suggest that) but he's put over 100k miles on it with zero issues
  10. Oct 4, 2012 at 6:20 AM
    rockgecko03
    Ben
    Rockwall, TX
    2000 4runner
    The general consensus regarding the UCA's is that you're usully fine up to about 2.5" of lift. Once you go over that, you will more than likely need to replace them if you want to get an accurate alignment.
  11. Oct 4, 2012 at 7:47 AM
    ryanr623
    I will be taking pics once i get my mud terrains on, should be soon, i'll make sure to take pics before i add the billsteins. It made a noticeable difference. Wit AC's you get more lift than DC's as well :)
