5100s with one 1/2" and one 1/4" spacer to correct taco lean?
Discussion in 'Suspension' started by TRD6Speed, Jul 31, 2012.
  1. Jul 31, 2012 at 10:17 PM
    TRD6Speed
    TRD6Speed [OP] senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    Like the title says......I have 5100s on the way and a set of 885s already. I know you cant use the toytec trim packer with 5100s but was hoping that the use of a 1/2" spacer on the driver side and 1/4" on the passenger wold achieve the same thing. I want a full 3" or as close as possible.
  2. Jul 31, 2012 at 10:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can do that but will need longer top studs at least on the 1/2" spacer side
  3. Jul 31, 2012 at 10:24 PM
    TRD6Speed
    Bill
    East Hartford, CT
    ok....so thats just a matter of ordering longer studs? cant be that pricey. Thanks for quick response.
  4. Jul 31, 2012 at 10:27 PM
    OZ-T
    Peter North
    British Columbia
    You can get a pair of 1/2" top plates and studs here
  5. Jul 31, 2012 at 10:38 PM
    TRD6Speed
    Bill
    East Hartford, CT
    Ya but then I would need another 1/4 for the taco lean.....so I figured I could just get relentless taco to make me one of each rather than stack em. Then just grab longer studs seperate.
    Anything else I need as far as hardware? new stuff I cant reuse or shouldnt? Front end only.....back end is next project.
  6. Jul 31, 2012 at 10:41 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Thats what im running. Except with eibachs. Im sitting at 22 3/4" hub to fender on each side.
  7. Jul 31, 2012 at 10:41 PM
    OZ-T
    Peter North
    British Columbia
    You'll have to contact Toytec to see if they will sell the studs seperately
  8. Jul 31, 2012 at 10:45 PM
    TRD6Speed
    Bill
    East Hartford, CT
    so you have a 1/2 inch or 2 stacked 1/4"? THanks for the input
  9. Jul 31, 2012 at 10:46 PM
    TRD6Speed
    Bill
    East Hartford, CT
    They prob are just a part at auto stores or other online source too if toytec wont seperate. We shall see....thanks for input bro.
  10. Jul 31, 2012 at 11:03 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    You can't stack top plates. You will have to ask toytec to mix and match one 1/2 and a 1/4". The 1/4" side can use factory bolts. If you have to order two different sets I am sure you could sell the other mix and match on here pretty easily.
  11. Jul 31, 2012 at 11:12 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    1/2 on drivers and 1/4 on pax.
  12. Aug 1, 2012 at 5:09 AM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Wheelers sells the longer top plate bolts, they are pretty cheap too, that is where I got mine, think I paid $5 in shipping for just those shipped.
  13. Aug 1, 2012 at 5:30 AM
    crawldad
    crawldad Well-Known Member
    2016 TRD OR 4X4 Quicksand
    i'll go half with you on the 1/2" spacer and send you a 1/4" spacer.
  14. Aug 1, 2012 at 5:54 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Sure you can. I'm running 1/2 and 1/4 on driver's side and 1/2 on the passenger.
  15. Aug 1, 2012 at 7:52 AM
    ffemt2987
    Austin
    Golden
    I guess "can't" was the wrong word.
  16. Aug 1, 2012 at 8:18 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    So can you just run a 1/4" one on the drivers side? I don't want to lift the truck anymore then it already is with my 5100s at .85 and Eibachs. What's my options?
  17. Aug 1, 2012 at 8:21 AM
    OZ-T
    Peter North
    British Columbia
    Yes
  18. Aug 1, 2012 at 8:34 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Do they go on the front and rear? And are all Tacos the same and need them?
  19. Aug 1, 2012 at 8:37 AM
    TRD6Speed
    Bill
    East Hartford, CT
    Ok here are my measurements as of right now....
    center of hub to fender (not with full tank......should I remeasure with a full tank guys?)
    LF 20 1/4" + 1/2" spacer
    RF 20 1/2" + 1/4" spacer
    LR 21 5/8"
    RR 22 3/8"
    So I was thinking of grabbing from relentless two spacers cut at different heights. As above....am I thinking correctly? Will I need larger spacers to get close to 3"? Im an access cab with no extra weight......my springs say 885 not 885x also if that matters.
  20. Aug 1, 2012 at 8:38 AM
    Bama_TACO
    Winfield, AL
    They go on the front only. A majority of Tacomas need them to make them sit level.
