5100s with one 1/2" and one 1/4" spacer to correct taco lean?
Discussion in 'Suspension' started by TRD6Speed, Jul 31, 2012.
  1. Aug 1, 2012 at 8:39 AM
    TRD6Speed
    TRD6Speed [OP] senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    only fronts get spacers and add lift.....the rear is lifted by larger leaf packs or blocks.....the rear shocks ride better than stock though so thats why we get them.;)
  2. Aug 1, 2012 at 9:14 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Dude , you've been on here for over a year , c'mon , you gotta know this stuff by now
    Add a 1/4" top plate spacer to your driver's side of your billy / eibach combo to fix the taco lean .
    Rear lift can be acheived with a block ( no ) , AAL ( better ) , or leaf pack replacement ( best )
  3. Aug 1, 2012 at 9:24 AM
    TRD6Speed
    Bill
    East Hartford, CT
    So does this seem about right? I dont think I want a 1/2" and 3/4" like the guy with the DCLB cuz im just an access cab......but level or slight bit of rake is what im after once I get dakars too.
  4. Aug 1, 2012 at 9:45 AM
    OZ-T
    Peter North
    British Columbia
    Hard to know cause you have old 885's , they may have sagged
  5. Aug 1, 2012 at 11:07 AM
    TRD6Speed
    Bill
    East Hartford, CT
    Ya........so taking that into consideration I feel I can safely put a 1/2" or 3/8" spacer on the driver side to get close to but not go over 3ish" and cause bad cv angles. I'll just do a 1/4 inch on passenger and call it a day.
    Thanks for the help guys.
  6. Aug 1, 2012 at 12:18 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    How would I know if I never looked it up before? I have a life outside this site, I'm sorry. My taco does lean though and I never knew why
  7. Aug 16, 2012 at 11:54 AM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    LOL, this thread makes me feel better. My aftermarket tires only rub on the driver's side, and I was beginning to worry that we screwed up the 5100 install somehow.
    So, OP, 1/4" spacer, have you installed it and how does it look? Did you end up needing longer bolts? Would this also explain how, when installibng my sliders, the driver's side slider was rubbing the bottom of the body, and had to be shimmed down 1/4"?
  8. Aug 16, 2012 at 12:30 PM
    MrsPib
    Angie
    Texas
    5 minutes later....
    Ordered one! Now I can get the damn spacers out of the sliders, put my mudflaps back on.....and lift my 5100 to the highest notch for good measure. SCORE! You, gentlemen, have made my day.
  9. Aug 16, 2012 at 12:34 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Remember that the 1/4" spacer will add around 1/2" to the side you put it on. If you put the 1/2" spacer on it will give you 3/4" of lift like the toytec link says it will.
  10. Aug 16, 2012 at 1:05 PM
    MrsPib
    Angie
    Texas
    Are most trucks running both spacers then, to get a true 1/4" difference?
    If so, can I buy anyone's extra 1/2" spacer off of them?
  11. Aug 16, 2012 at 1:42 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Im still trying to figure out what spacer Im buying myself too. I have 1/2 lean in the drivers rear and was told the 1/4" spacer will fix that. Im thinking about doing the 1/4 on the passenger and 1/2 on the drivers though to get a tad more lift. The spacer wont effect the truck alignment right? Im just worried about going past the 2.5" in the front and not getting a good one
  12. Aug 16, 2012 at 1:44 PM
    OZ-T
    Peter North
    British Columbia
    It will
  13. Aug 16, 2012 at 1:58 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I have Billies @ .85" with eibachs and a 1/2" spacer on the driver side and 1/4" spacer on the passenger side. It gave me pretty much a full 3" lift up front and no lean.
  14. Aug 16, 2012 at 3:23 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    did you get UCAs?
  15. Aug 16, 2012 at 3:37 PM
    #35
    Haslefre
    Brady
    TN
    2019 Tundra
    On my IronMan lift I had to put on the 1/4" spacer to correct it... after I figured out that the majority of my lean came from leaving my sway bar off...
  16. Aug 16, 2012 at 4:47 PM
    #36
    ajohnson
    Andy
    Charlotte, NC
    Yes, Light Racing UCA's.
  17. May 15, 2019 at 11:06 AM
    #37
    JazzyMagee
    JazzyMagee Well-Known Member
    SWFL
    2011 TRD Offroad, 2019 TRD Offroad
    I know this is an almost 7yr old thread, but can the sway bar really affect the “taco lean” ?
  18. May 15, 2019 at 11:15 AM
    #38
    Haslefre
    Brady
    TN
    2019 Tundra
    It can. The sway bar is there to prevent rolling and uneven driving. Without it on it can make the lean more noticeable, not saying a 1/2" but maybe 1/4" of it was it being off.
