5100s with or without driver side spacer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jws6295, Sep 18, 2020.
  1. Sep 18, 2020 at 12:37 PM
    jws6295
    jws6295 [OP] Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    Hey guys! Might be picking up a set of 5100s this weekend that’s if all goes well anyway. Once I get them I’ll order the driver side needle bearing and do the lift at some point. Planning on running it the 0.65” or maybe the 1.1” setting on stock coils so it gives it a decent level look without going crazy on lift. Question is do I need to do the 1/4” spacer as well?! I’ve heard it both ways. Some people say with stock coils I wouldn’t need it some people do. Anyone been through this?
  2. Sep 18, 2020 at 12:50 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    As far as stock coils and the spacer.
    I yet to see the difference between pass. a driver’s sides coils. In my case the total length of the assembly, length of coils and the markings are the same.
    Browsing Toyota parts catalog for my trim is inconclusive. But some folks are saying that the driver’s side lean is compensated in the coils.
    jws6295[QUOTED][OP] likes this.
  3. Sep 18, 2020 at 12:58 PM
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    As far as I can see from the browsing the Toyota parts catalog, the part number are exactly the same for non TRD Pro trucks.
    jws6295[OP] likes this.
  4. Sep 18, 2020 at 1:02 PM
    Vlady
    Issy, WA
    That what I see. When I took my struts out I forgot to mark sides and spent some time to figure it out. Both struts have components with the same part #.
    Op, I would get the spacer.
  5. Sep 18, 2020 at 1:10 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    I would measure from wheel hub center to fender on both sides, if drivers side is.lower by 1/4 -1/2 inch, yes, add the spacer.
  6. Sep 18, 2020 at 1:12 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Yes add 1/4” spacer
  7. Sep 18, 2020 at 1:16 PM
    vinces_ego
    vinces_ego Well-Known Member
    PA
    2016 MGM Tacoma SR5 V6 4X4 DCSB
    Depends on how particular you are. Did not put a spacer on and my lean is exactly 1/2” and I notice it every time I look at the truck. 5100s (1.5” notch) with stock coils. My only regret is not doing it when I had everything apart and hesitant to do it now after playing around with alignment and eliminating vibrations.
    jws6295[OP] and 02Duck like this.
  8. Sep 18, 2020 at 4:07 PM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    A lot of the charts floating around for 5100 lift heights will suggest running the driver's side one clip higher instead of a spacer.
  9. Sep 18, 2020 at 5:33 PM
    jws6295
    Central PA
    I thought about that method as well! Not sure which way I’ll go. Figured I’ll order spacer too for all the more they cost. I’m planning on doing the ECGS bushing too while I have everything apart.
  10. Sep 19, 2020 at 2:13 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    1/4 spacer, would not recommend two different settings. The shocks would respond differently base on what's I have been reading.
