5100s with stock coils clunk noise maybe? Has anyone experience this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mytaco77, Nov 30, 2014.
  1. Nov 30, 2014 at 3:16 PM
    mytaco77
    mytaco77 [OP] Well-Known Member
    So Cal
    08 dbsb 4x4 TRD
    I'm search the threads and can't really find anyone having the same problem but, I just took my truck on some dirt trails to try to locate/find a fix for the clunk I hear. Here's my setup:
    5100s on all 4 corners.
    The front billy's are set at 1.75" with stock coils
    New 3 leaf pack in the back which provides about 1.5" lift in the rear
    Tires are Hancook Dynapro ATs 265/75/16
    Is it possible the stock coils are too short? When I was on the dirt trail and hitting the bumps a little harder, I hear a clunk noise. It seems like its the suspension and not the brakes because I won't touch the brakes and hear the clunk.
    Maybe I should go with the eibach coils? Thoughts?
  2. Nov 30, 2014 at 3:20 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Should post pics of the whole coil so people can see if it is put in correctly. Should be no clunk at all. Stock coils are plenty long enough, since you are compressing them and making them smaller I am sure it is not them
  3. Nov 30, 2014 at 4:20 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    He saying he's using stock coils with the 5100's.
    Stock coils are fine to use with 5100's. As Unchained said, they could be installed incorrectly. The bushings at the top might be missing. Any number of things could cause the clunk. If you can, try to get some close up pictures of the suspension.
  4. Nov 30, 2014 at 4:27 PM
    Pigpen
    Dan
    Northwest Montana
    I'm sure, like me, he did it for the money
  5. Nov 30, 2014 at 4:30 PM
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    I get some noise but it seems pretty normal after hearing it in other trucks. It may be feed back from the steering rack...
  6. Nov 30, 2014 at 4:31 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Did you loosen your LCA's at all?
    Sounds similar to a lca bolt that's not tight enough.
  7. Nov 30, 2014 at 4:34 PM
    Texas Aggie
    Texas Aggie Well-Known Member
    Michael
    TEXAS
    2013 SR5 4x4 Lifted
    King 2.5's Front and Rear 700# coil, 2" wheelers aal, 315/75R16 BFG KM3's Pelfreybilt Front and Rear Steel Bumpers, All Pro Sliders, 4.56 Gears
    Something wasn't tightened all the way. Look over your suspension and find what's loose
  8. Nov 30, 2014 at 5:25 PM
    acolsch
    acolsch Member
    Andy
    McGuire AFB, NJ
    05 Tacoma
    DVD Player
    Just put in struts on my 2004 Taco. Reading through a ton of forums on clunk noise, could be anything.... used a stethoscope to find the noise and believe its the sway bar link. Yes, the 2nd gen Tacos don't need to remove that link, but I also loosened the LCA bolts to get the arm low enough to install.
    A little worried I didn't figure it out, but part comes in tomorrow. i'll let you know.
  9. Nov 30, 2014 at 6:06 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I have a brand new sealed bag of the 5100 bushings if you need them let me know. I'll ship then right out to you priority mail for free
  10. Nov 30, 2014 at 6:53 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    stock UCA's?
    theres the problem. The upper ball joint flexes to its max before the end of the stroke of the shock. Essentially the Upper ball joint limits the down travel of the front suspension and not the shock. This causes the hard hit.
  11. Nov 30, 2014 at 8:41 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Make sure your coil spring is seating good and is Straight. I had a clunking type noise after installing my 5100 then I realized I didn't have the spring seated properly.
    Good luck
  12. Dec 1, 2014 at 6:01 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yeah I think UCA's have absolutely nothing to do with it. Bushings or spring seat, but we are all waiting for a pic of the full coil set up
  13. Dec 1, 2014 at 6:25 AM
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    If you're running without dust covers you should've grabbed the spacer from them and put them below the lower metal retainer. From bottom to top on the strut shaft it should go:
    dust cover spacer
    metal lower retainer
    rubber bushing
    top hat
    rubber bushing
    metal upper retainer
    top hat nut
    Also, This obviously does not include the rubber bushing that seats the coil on the top hat.
    Leaving out any of these parts could result in a clunk.
  14. Dec 1, 2014 at 7:47 AM
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    Thanks everyone for your response. So here's the deal...I took them off myself originally and had it set at .85" but there was too much nose lean. So the next time around I took it to Midas to adjust it to 1.75" because I hate dealing with those POS autozone spring compressor (I always feel like those things are going to burst open). I'm going to do a thorough examination and post pics. Hopefully, it's just the way the suspension is sitting. It's really annoying though because sometimes just braking, I'll hear something (clunk) shift around.
    Thanks again.
  15. Dec 1, 2014 at 8:00 AM
    moondeath
    Pa, Gardners
    Just an fyi. You don't need the those junk spring compressors to change out these coil overs. Theres a very safe decompression method while leaving the bottom of the coil over still bolted in place. I've used it twice with 2 different trucks changing over to 5100s.
  16. Dec 1, 2014 at 9:38 AM
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    Can you post me a link? I would like to learn about this.
  17. Dec 1, 2014 at 9:43 AM
    moondeath
    Pa, Gardners
    Heres a video. He has a disclaimer of course, but the method is very safe. Many have used it including myself. The main thing is, the coil over is still bolted in place so there is no where for the spring to escape to. It's very simple and makes the whole disassemble very quick.
    http://m.youtube.com/watch?v=vkVLBOnAifc
  18. Dec 1, 2014 at 10:01 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I just did the 5100's at 1.75 and now want to put the Eibach Springs on. Who's up for it? This does look kind of easy.
  19. Dec 1, 2014 at 10:03 AM
    el tardo
    el tardo Well-Known Member
    only took me a hour per side,very easy to do (im only 2x4)
    FYI if your a 4x4 it will take a whole lot longer as something is in the way,lol
  20. Dec 1, 2014 at 10:08 AM
    DoctorStrobe
    DoctorStrobe Active Member
    Check to see if the lower bushing washer (sits on top of dust boot) was transferred from the old shock. I had forgotten to do this when I first installed mine...
