5100s with stock coils clunk noise maybe? Has anyone experience this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mytaco77, Nov 30, 2014.
  1. Dec 1, 2014 at 1:06 PM
    #41
    mytaco77
    mytaco77 [OP] Well-Known Member
    So Cal
    08 dbsb 4x4 TRD
    I'm going to pull off the tires tomorrow and check the brakes and any loose connections from the suspension.
  2. Dec 1, 2014 at 2:53 PM
    #42
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I'm telling ya.... Stock upperball joint limiting down travel.
  3. Dec 1, 2014 at 2:57 PM
    #43
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Mine has never made any noise with the stock uca. 5100s at 1.75" with stock springs.
  4. Dec 1, 2014 at 3:06 PM
    #44
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    It's probably limiting it but, I'm not doing any crazy off-roading just some intermediate stuff and dirt trails.
  5. Dec 1, 2014 at 3:13 PM
    #45
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I have a feeling that the bottom mounting part where you can adjust the height is on upside down. hard to tell from your pics
  6. Dec 1, 2014 at 3:30 PM
    #46
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
  7. Dec 1, 2014 at 4:23 PM
    #47
    el tardo
    el tardo Well-Known Member
    i bet its your muffler bearings :D
    or your piston return spring thats going out :eek:
  8. Dec 1, 2014 at 4:46 PM
    #48
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    I think your coils may be inverted after comparing yours to mine. Thats the only thing I can think of unless its missing bushings or retainers under the top hat.
  9. Dec 1, 2014 at 5:01 PM
    #49
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The coils are correctly oriented. The brown anti-slap sleeve that is wrapped around the last coil should be at the top. Picture of factory OEM Bilstein for reference:
    I suspect the shop didn't get the stackup of center shaft washers and bushings in the correct order, or omitted some parts by mistake.
  10. Dec 1, 2014 at 9:16 PM
    #50
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    I'll agree with this as well. You do not have enough travel. That is if everything was installed right.
  11. Dec 1, 2014 at 10:08 PM
    #51
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    Mine clunk after an alignment. The bolt where they adjust it was not tight enough. Needs to be 100 ft lbs torque if i remember. So getting down there with a ratchet to check if it's tight will not work. You need a torque bar.
  12. Dec 2, 2014 at 7:45 AM
    #52
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    This could be it too. When I had the lift adjusted to 1.75", I got the alignment done right away. I had my buddy at the tire shop recheck the alignment cause I told him it was clunking a little.
    I think it's time for me to get dirty tonight. I'm going to check my brakes, suspension and that alignment bolt tonight with the tires off.
  13. Dec 2, 2014 at 8:45 AM
    #53
    surfinsteve
    surfinsteve Member
    Steve-O
    Calgary, Canada
    07 Dbl Cab
    Billy 5100's front with 2.5" and rear stock, driver seat raised, dynomax muffler
    Hey mytaco77,
    I recently did my 5100's, but set to 2.5", and I too had a knock that i couldn't figure out. Felt like it was coming from under my feet, and only occured once in a while.
    Lifted the truck up plenty of times, and couldn't replicate the sound. Then finally, i took a rubber mallet and a long pry bar to see if I could hear any hollow sounds from a hit, or find any movement.
    Turns out, one of the bushings in the swaybar was gone, and enought to bounce it around on the random bump, or hard braking.
    Pulled the sway bar out completely, and the knocking is gone.
    Suggest just getting under the truck and give the sway bar a yank in a few different directions and see if that remedies anything?
  14. Dec 2, 2014 at 8:46 AM
    #54
    pudge151
    Sean
    Connecticut
    maybe the sway bar is loose?
  15. Dec 2, 2014 at 9:27 AM
    #55
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    Ok here's my check list for tonight:
    1. Get a torque wrench and make sure the alignment bolt is at 100lbs
    2. Check the brakes and make sure its all tighten correctly
    3. Check the sway bar bolts
    4. Double check all the suspension bolts
  16. Dec 2, 2014 at 6:53 PM
    #56
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    Alright so I found the issue. The passenger side alignment bolt was really loose and after tightening to 100lbs the issue is gone. I'm going to test on the dirt this week and see what happens but, there is no more clunk when I shift in gear or over speed bumps or when I back into my driveway. This was driving me nuts you have no idea.
    Hats off to everyone for the help. Thanks for your insight. Best forum.
  17. Dec 2, 2014 at 7:15 PM
    #57
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    How does it ride at the 1.75" with the Trd coils. I'm assuming you have the off road coils?
  18. Dec 2, 2014 at 7:15 PM
    #58
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Just did mine at 1.75 and it rides amazing. I have a TRD Sport 2015
  19. Dec 2, 2014 at 7:16 PM
    #59
    Greytacoma1
    dave
    Sacramento ca
    Tacoma dc lb
    Glad you got it fixed.
  20. Dec 2, 2014 at 7:17 PM
    #60
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    It rides nice. I've never rode in a Taco w/ 5100s w/ eibach springs so I have nothing to compare it to but, I had complements on how smooth my ride is. Yes, I have the TRD Off Road Stock springs.
