5100s with stock coils clunk noise maybe? Has anyone experience this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mytaco77, Nov 30, 2014.
  1. Dec 2, 2014 at 7:19 PM
    #61
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Yeah I'm on the fence about which way I want to go. I've read the sport and off road coils ride totally different with 5100s
  2. Dec 3, 2014 at 8:08 AM
    #62
    mytaco77
    mytaco77 [OP] Well-Known Member
    So Cal
    08 dbsb 4x4 TRD
    Which one is better from what you've heard?
  3. Dec 4, 2014 at 7:23 AM
    #63
    DBTaco
    NC
    I've heard the sport coils are a smoother ride b/c they are linear vs the offroad coils being progressive. Whatever that means.
  4. Dec 4, 2014 at 6:29 PM
    #64
    2012reg4x4
    2012reg4x4 Well-Known Member
    brian
    Downingtown, pa
    14 trd sport dcsb
    Rigid sr10inch, rigid duallys on cbi pillar mounts, bamf sliders, Jason cyber camper shell. 5100s at 1.75, wheelers aal 1.5 inch.
    Glad I found this as I just did an install with 5100s and stock trd sport springs at 1.75 and have had it about 2k miles and just got a small clunk. Can't imagine it is anything wear related, my truck only has 8k on it total. I did loosen my lca's so I'll check the bolts for those tomorrow.
  5. Dec 4, 2014 at 6:56 PM
    #65
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Thats what I thought... glad you found the issue.
  6. Dec 5, 2014 at 7:48 AM
    #66
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    Had to get under the truck again last night. I initially only tighten 2 out of the 4 alignment bolts so now I'm good :)
    One thing I'm a little pissed about is the people who did my alignment broke the clip that goes on the tie rod dust cover so they zip tied it. I had some the alignment parts seized so they put on new ones but, now I have to buy a new driver side clamp. The dust cover was completely off.
  7. Dec 7, 2014 at 3:14 PM
    #67
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    Man, I have had this clunk sound for a good while now and it's embarrassing... I need to check everything from sway bar, alignment bolts, etc...
    The clunk happens when I go over small bumps, accelerate, or turning the steering wheels.. time to find the issue
  8. Dec 7, 2014 at 10:24 PM
    #68
    crazybushcreature
    crazybushcreature Member
    I just did the bilsteins too and i get a lil bit of a clunk when i go from reverse into drive or drive to reverse. other than that when im driving over bumps or anything else i dont hear it. only from forward to reverse or vise versa. Someone told me it may be my rotors shifting and could be normal maybe?
  9. Dec 8, 2014 at 7:48 AM
    #69
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    I would double check those alignment bolts first. They're pretty easy to get to once you remove the skid plate.
  10. Dec 8, 2014 at 9:33 AM
    #70
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you were getting clunking from the alignment bolts being loose... its highly likely your alignment is now messed up...
    Take it back to the shop and have them redo the alignment, take a torque wrench with you and torque the 4 bolts down in the parking lot.
    BTW to the above, i rock TRD OR coils at 1.75 on my truck, and i love the ride, its not harsh at all.
  11. Dec 8, 2014 at 9:44 AM
    #71
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    I can attest to this as I've been on both. When I first got the 5100s they were used and came with OR coils. Ran those for a little while and they were slightly stiff compared to my stock sport springs which I then ran for some more time. The 5100's were set on the highest setting... During this time I heard no clicks or noise and I ran them pretty hard with the sport springs on. Member Carcharias also was having a similar clicking issue too (not on 5100's though) and end result I believe was needed a new LCA bushing or just needed to retorque the bolts...can't remember.
    But as a side note, now i'm on 5100s at the lowest setting and running OME 887's and the ride is so much better than either of the stock coils. for only $180 I highly recommend them! :thumbsup:
  12. Dec 8, 2014 at 10:02 AM
    #72
    nd4spdbh
    SoCal
    how much lift did you get with the 887's? you rockin aftermarket UCA's?
  13. Dec 8, 2014 at 10:07 AM
    #73
    Shauncho
    Shaun
    Parts Unknown...
    none
    I didn't have a level surface easily available to do measurements however it seems to sit as high if not a little higher than what I was getting with the stock coils on the top setting of the 5100s.
    and yes, I have the TotalChaos UCAs.
  14. Dec 10, 2014 at 8:14 AM
    #74
    mytaco77
    So Cal
    08 dbsb 4x4 TRD
    I took the truck out last night on the dirt and no more clunking. I hit some of the whoop sections a little hard too and still no clunk so it was definitely the alignment bolts. Thanks again.
