5100's with Top Plate Spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Agent7, Nov 1, 2009.
  1. Nov 1, 2009 at 6:17 AM
    Agent7
    Agent7 [OP] Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    Okay, so I realize that you can't obviously run a large 2-3" top plate spacer with the 5100's cause there would be way too much preload on the springs. How about the small 1/2"-3/4" spacers? Is it possible without overloading the springs? Also would it force the stock control arms down to far, or would they still be able to handle it? It doesn't seem like it would add so much that it would risk damaging the components but I would like to hear someone has done it with success before I attempt to do it. The whole reason is, I don't have rubbing issue's with my 33's when my truck isn't loaded (no actual cargo and not filled with people). As soon as I add around 500 hundred pounds of weight I will get some rubbing when the suspension compresses (only when turning though). I really just need an extra 3/4" clearance so that when there's a load on the suspension it won't rub the fender (my truck constantly has cargo/equipment in it). I don't want it to rub under regular driving condition while turning...
    Thanks for any input! :cool:
  2. Nov 1, 2009 at 6:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Kind of a grey area there. Some have had no issues running a small 10mm top plate, while others have needed to extra droop allowed by a uniball UCA.
  3. Nov 1, 2009 at 6:27 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    You can run a 1/4 to a 1/2 inch spacer along with the billy 5100s but any lift 3" and above will put some stress on your stock UCAs and you'll end up with some alignment issues....I think :)
  4. Nov 1, 2009 at 7:21 AM
    gcwaterski
    gcwaterski Well-Known Member
    Oh so you could add a 1 inch spacer to the billys set at 1.75?
  5. Nov 1, 2009 at 9:56 AM
    Agent7
    Toronto, Canada
    Hmmm... don't you love the grey areas. So Chris, the 10mm spacers land right inbetween the 1/4" and 1/2" spacers... and I assume your talking about the billy's set at 2.5"? So how much over all lift did it add? 5/8"? What 10mm spacers are they? And last but not least... do you have to remove the strut assembly to add them in or can you squeeze it without doing it? Thanks alot! :)
    Somehow I think I'm going to be spending alot more money...
  6. Nov 1, 2009 at 9:58 AM
    ColtsTRD
    Scott
    AZ
    It's a sumbitch ain't it? :frusty:
  7. Nov 1, 2009 at 9:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Personally, I wouldnt add the 10mm spacers without having UCA's that had a Uniball. The 10mm spacers need longer studs, so a disasemble of the spring/shock is in order to install them.
  8. Nov 1, 2009 at 10:27 AM
    Agent7
    Toronto, Canada
    Damn, I knew it... okay so like $60 for the spacer kit, $500 for UCA's, and because I'm already thinking I should have gone higher in the rear another $500 for a 3" leaf pack. This is probably going to wait until after Christmas... but for the mean time, I may just buy the 1/4" to get an additional 1/2" of lift and keep my eye on it. It may be all I need to get the clearance I want anyways. For $40 you can't go wrong. I like to dabble in the grey areas anyways... :)
  9. Nov 1, 2009 at 10:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Jun 25, 2014 at 9:56 AM
    Skyrebel88
    Skyrebel88 Member
    Danbury ,ct
    2012 dbcd sr5
    884 with 5100 Billy's, overload leaf removed and aal added= stock uca's =ok=2 inch lift. I want to go higher though.
    HAs anyone installed the 5100 with out the coil over and actuated the suspension to full compression to see if the strut bottomed first or the bump stop on the a arm? Anyone have issues with strut bottoming or cv boots tearing with the top plate spacer on both sides?
