5100s
Discussion in '1st Gen. Tacomas (1995-2004)' started by dtay4197, Nov 23, 2015.
  1. Nov 23, 2015 at 5:48 PM
    dtay4197
    dtay4197 [OP] Well-Known Member
    Dustin
    silver 2007 trd offroad
    2.5 bilstiens, colormorph retrofit halos and fogs, urd maf cal, Urd tcai, 20x12 mo962, 33x12.50x20 iron man mts
    I have ordered aa set of 5100 adjustable shocks for my 07 taco and someone told me having them set highest setting would result in having to get newUCA's to have truck alligned? I talked to my mechanic and he told me i would be fine with stock UCA's. Anyone have any advice?
  2. Nov 23, 2015 at 7:05 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    This is the 1st gen section but yes they are designed to work with stock components (aftermarket uca may still help but not necessary)
  3. Nov 23, 2015 at 7:14 PM
    dtay4197
    Dustin
    Ah geez I didn't realise I was in first gen I was actually scrolling through first gen and went to create a post and forgot to change it. But thank you for the info
  4. Nov 23, 2015 at 7:15 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    it will cause premature wear and possibly mess up cv's if you crank them to the 2.5 setting, also depending on what springs you are using, that will also be TOO TIGHT of a fit (spring compressed too much). If you keep it no higher then the 1.75 setting (1 ring from the top) you should be fine. I dont think youll be able to get "perfect" factory specs for alignment either, which can also cause irregular tire wear and alignment issues. Dont know your mechanic but if its a bum shop on the side of the road, chances are they dont have your best interest in mind and just want your money, but you know your surroundings better.
  5. Nov 23, 2015 at 7:32 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    I ran 5100's at 2.5 with stock coils and stock UCA's for 10 months and had no issues even when wheeling. I was able to get my alignment good, i do however have to run +0.5* of camber help my caster. It did wander at highway speeds though. The ride was firm (some say rough.... it's a truck. Enough said). I went with new coils and UCA's recently to really get the most out of this set up. That being said......
    You'll be fine at 2.5 with stock coils and UCA's. 5100's are a good shock, especially for lifting a truck on a budget. Just save up and build on this setup like i did with mine, or if you have have plans for a beefier setup like icon/fox/kings later on go that route and run this setup as a temporary setup.
  6. Nov 23, 2015 at 7:36 PM
    bzzr2
    bzzr2 Well-Known Member
    you will be all set for a budget front lift with just the shocks set at 2.5. remember that your current coils are 8yrs old, they don't sit as tall as they once did and aren't as stiff anymore as when new. others are right when they say the alignment may not be perfect, but it should fall within the far end of factory spec if not very very close to it.
