5125 or 5100?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Jun 30, 2012.
  1. Jun 30, 2012 at 3:59 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Which ones rear shocks would you recommed me ?? My truck has the stock leafs. I have 5100 up front and love them. Would the 5125 be as smooth as the 5100 are up front??
  2. Jun 30, 2012 at 4:19 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    the 5125s are for a lifted truck, so they would be too long for your stock leafs. just get rear 5100s
  3. Jun 30, 2012 at 4:24 PM
    Hektor
    Texas
    Really didnt know that.
  4. Jun 30, 2012 at 4:24 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    5125's are for lifted rear but I run them with my stock leaf with no problem. And no it was not to long it works just fine. But if you aren't lifting stick to 5100's.
  5. Jun 30, 2012 at 4:26 PM
    Hektor
    Texas
    I dnt plan on lifting my truck. Maybe in the future Ill be getting 5 pack wheelers leafs
  6. Jun 30, 2012 at 4:28 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh, my bad, you can custom order the sizes and valving on 5125s so you get the right length if you are not lifted.
  7. Jun 30, 2012 at 4:33 PM
    sirsaechao
    Tim
    Commifornia
    I ran the 8.6 travel 5125's on my stock leafs and when I ordered them Wheelers had it posted and also confirmed it was for 0-3" lift rear but like I said stick to the 5100's if you don't have a lift.
  8. Jun 30, 2012 at 6:58 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I ran 5125s on stock height and they worked great.
  9. Jun 30, 2012 at 7:22 PM
    Hektor
    Texas
    How the ride??
  10. Jun 30, 2012 at 7:47 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I love this common misconception....
    5100's are generally referred to as the front adjustable shocks.
    5100 series shocks includes 5100's, 5125's, 5150's (now discontinued), 5165's, etc..
    If you are not talking about front adjustable 5100's, then don't call the shocks 5100's.
    They make 8" and 8.5" travel 5125's for the rear of our trucks.
    So, yes you can get them for stock height rear, and yes they will ride as smooth as the front 5100's you have.
  11. Jul 1, 2012 at 12:44 AM
    04tacomaSR5
    04tacomaSR5 Proud Canadian
    British Columbia, Canada
    2005 Tacoma TRD Sport 4x4
    Toyota hard tonneau cover, custom seat covers, nerf bars, more to come...
    I'll be putting new OME dakar leafs (3" lift) will the bilstein 5100's for the rear ride smooth and have good flex or do I have to go with 5125's?
    any advice will help before I purchase the set up...
  12. Jul 1, 2012 at 2:10 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    I Coulda sworn 5100's in the rear were good for 0-3" of lift.. but i guess not, i blew out one of my shocks... leaking oil... only had for like 5 months???
  13. Jul 1, 2012 at 6:11 AM
    humtaco
    humtaco Well-Known Member
    If you buy shocks with long travel you can bottom them out if you are still using stock bump stops with little or no lift. I confirmed this with the Wheeler's 5 leaf, but I use timbrens so not a problem. There's a thread where the guy from Downsouth talks about it too.
  14. Jul 1, 2012 at 8:04 AM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I give up.
  15. Jul 1, 2012 at 9:17 AM
    04tacomaSR5
    how does the 5125 ride?
