5125 vs OME N182?
Discussion in 'Suspension' started by Whistler_Steve, Feb 25, 2011.
Which rear shocks to match up with my Icon 1.5" AAL
  1. Bilstien 5125
    3 vote(s)
    27.3%
  2. OME N182
    6 vote(s)
    54.5%
  3. Other
    2 vote(s)
    18.2%
  1. Feb 25, 2011 at 5:00 PM
    Whistler_Steve
    Whistler_Steve [OP] Well-Known Member
    Stephen
    Whistler, Canada
    06 Radiant Red TRD Offroad
    Icon Ext Travel Coilovers--LR Upper Control Arms--Icon 3 Leaf AAL--OME 182 Rear Shocks--BFG KM/2 285/75/16--Replica TT TRD FJ Wheels
    I just pulled the trigger on a set of Coilover's and 1.5AAL pack from ICON. I'm looking to get some shocks to go with it but the Icon Remote Reservoir's just seem like overkill for the type of stuff i'll be doing.
    So my question is which shocks to go with?
    Bilstien 5125's or OME N182's?
    Or should I go with something else all together?
    Thanks for the input!
  2. Feb 25, 2011 at 5:08 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    5100's. The 5125's are just custom length 5100's
  3. Feb 25, 2011 at 5:09 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i voted 182 because they are long travel and what i just got from the fedex guy a few days ago....and they are nitro filled compared to oil piston internals.....better for your location
  4. Feb 25, 2011 at 5:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 5100's are nitro filled as well. The differences are:
    5100's are a high pressure nitro charge, vs. the OME low pressure
    5100's are a single wall mono tube shock, vs. the OME Double wall twin tube shock
    The OME's hold a bit more oil, and have a less aggressive speed dampening system, so they tend to ride a little softer than the 5100's. If you run unloaded most of the time, the OME shocks are the way to go. If you haul alot, or tow, I think the 5100's may be for you.
  5. Feb 25, 2011 at 6:14 PM
    crf69
    Ohio
    ummm yeah
    yeah thats what i meant:D
  6. Feb 25, 2011 at 6:18 PM
    Whistler_Steve
    Stephen
    Whistler, Canada
    Thanks Chris, That exactly what I was looking for, I rarely have much of a load other than a pile of snow in the winter and my bike in the summer so OME sounds like the better bet.
    I read somewhere that the 5100's had a lifetime warranty while the OME's was only 2 years...do you know if that covers rust? I went through a few pairs of rear shocks in my old truck so if I can get a lifetime warranty on that it's enough for me to make a minor sacrifice on ride.
    THanks again!
  7. Feb 25, 2011 at 6:26 PM
    Malamute
    Malamute Active Member
    Dan
    CO
    Not to hijack but what about with Dakars? Also, is travel about the same on them? I'm flip flopping back and forth with the same set up you are Steve, I want the c/o's but my logical side says go OME all the way around. I want the maximum travel I can get from IFS.
  8. Feb 25, 2011 at 6:29 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Dakars are the OME leaf pack (new leaf spring set)
  9. Feb 25, 2011 at 6:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 5100's would be less likely to rust, as they are aluminum. Not sure if the warranty covers corosion. You may want to E-mail Bilstien.
  10. Feb 25, 2011 at 6:30 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    This is the first gen set.
  11. Feb 25, 2011 at 6:57 PM
    Whistler_Steve
    Stephen
    Whistler, Canada
    Hmm that makes it a little more tricky to decide....slightly better ride or slightly better life :)
    Any options i'm not thinking of that are still in that price range? Ideally I'd like to stay below $200
