5160's at stock height..?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 360joules, Aug 1, 2018.
  1. Aug 1, 2018 at 6:58 AM
    360joules
    360joules [OP] FWC Stalker
    Troy
    Portland Oregon
    SOLD
    I have around 500 lbs consistently on/in the back of my DCSB. For the time being, I'm adding air bags to help support the weight and bring the back end up to approx stock height. I'm considering upgrading the rear shocks to be able to handle the weight better and am looking at 5160's.
    Is a collapsed length of 14.22" going to be too long to function well on an approximately stock height Taco?
  2. Aug 1, 2018 at 7:15 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    why not just add Sumo Springs? nothing to fail unlike air bags...
    Clay7160 likes this.
  3. Aug 1, 2018 at 7:24 AM
    360joules
    Troy
    Portland Oregon
    SOLD
    With sumos, I'd have the choice between the old 610's which would give me a bit of lift all the time or the newer 612 which wouldn't help anything unless I were sagging and resting on it (I'm trying to correct the sagging issue). I like the adjustability of the bags. I intend to keep them as a part of my setup once I get a full suspension upgrade and camper installed.
    Now, about those shocks...
  4. Aug 1, 2018 at 8:51 AM
    rogue.tacoma
    rogue.tacoma Well-Known Member
    Ed
    2017 TRD Off-Road 4x4 DCSB
    Shocks don't carry weight, you should be looking at Leaf Springs. Either AAL or a whole new pack.
    DrFunker likes this.
  5. Aug 1, 2018 at 8:53 AM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
  6. Aug 1, 2018 at 9:19 AM
    360joules
    Troy
    Portland Oregon
    SOLD
    Dear lord people. Springs and air bags are carrying weight. I’m upgrading my shocks. Focus. :)
  7. Aug 1, 2018 at 9:21 AM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    From what i understood the 5160s are good for 0-1” of lift.
    I had them when I was stock height and switched to the b110 5100s when I went up in height
  8. Aug 1, 2018 at 9:26 AM
    360joules
    Troy
    Portland Oregon
    SOLD
    Okay, info I’m reading says 1-3” for ‘05 plus. This must be like the fox suspension parts where for ‘16 plus you subtract 1” for actual difference. In that case it should work well.
    Thanks for your help!
    txtaco87[QUOTED] likes this.
