521600 on 5100's fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jsnyder31x, Dec 29, 2016.
  1. Dec 29, 2016 at 6:25 AM
    Jsnyder31x
    Jsnyder31x [OP] Well-Known Member
    JOL
    2015 TRD OR DCSB
    IMG_0084.jpg IMG_0085.jpg IMG_0083.jpg So I had 521600 2.5" springs installed on my 5100's set at zero with a 3/8" spacer in the drivers side and a 1/4" spacer on the passenger side to compensate for the lean. I got the truck back and the driver side front is now an inch lower than the passenger side front. I looked it over and everything looks ok.
    Any thoughts?
    If I pulled the driver side 5100 and set it at .85 would that mess up my alignment? Should I even preload the 521600? I do have an extra 3/8" spacer, should I stack that on top of the other 3/8" spacer? The passenger side is dead nuts even with the rear of the truck with the 1.5" aal.
    Thanks in advance!
    2009 base access cab V6 4x4 with a brush guard
  2. Dec 29, 2016 at 9:36 AM
    Marcus Israd
    Marcus Israd Well-Known Member
    Concord, CA
    09 TRD Sport SR5 4x4
    2009 Tacoma 4.0L Double Cab 4x4 Pyrite Mica Front: Yukon 4.88's ARB Locker Bilstein 5100's/Eibach Springs Camburg Uni-Ball UCA's Solo Motorsports Steering Rack Marlin Crawler LCA & Frame Braces Wheel bearings/Hubs by "05taco4x4" Crown Extended SS Brake Lines Stoptech Cryo Slotted Rotors/TRD Pads Wheeler's Super Bump Stops Rear: Yukon 4.88's ARB Locker Bilstein 5125's/All-Pro Expo Leaf Springs Ruff Stuff U-bolt Flip Crown Extended SS Brake Lines Timbren Bump Stops Intake/Exhaust: TRD CAI w/ AFE Dry-Flow Filter & TRD Exhaust (cut at axle) Lighting: Ultimate Headlight Upgrade by "crashnburn80" Fog light anytime mod Baja Designs S8 20" Light Bar Baja Designs Squadron Pro Fogs Armor: Pelfrybilt Steel Front Bumper BAMF Steel Skid Plates BAMF Weld-on Rock Sliders BAMF Front Bumper Supports Wheel/Tires: Pro Comp 17"x9" Wheels (x5) BFG KM3's - 35/12.5/17 Recovery: Warn M8000s Winch w/ Synthetic line Misc.: SoftTopper Ultra-Gauge Hurst T-handle Shift Knob Energy Suspension Urethane Radiator Support Bushings Pro Eagle Jack Midland CB Pine Tree Air Freshener Fluids: Amsoil
    Perhaps the spacers got mixed up and put on the wrong sides?
  3. Dec 29, 2016 at 9:46 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    My guess is that the passenger side 5100 shock is not set at zero.
  4. Dec 29, 2016 at 1:17 PM
    Jsnyder31x
    JOL
    2015 TRD OR DCSB
    Spacers were mixed up...The front is within 3/16" now. 521600 are definitely stiffer it not unbearable. Thanks for the info. IMG_0088.jpg
