Wheel Bearings & Hubs Press Service *** OE NSK ***
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Mar 4, 2018.
  1. Mar 4, 2018 at 9:21 AM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    *** NSK Bearings ***
    Original Equipment
    I DO NOT HAVE A WEBSITE
    I DO NOT SELL ELSEWHERE
    ONLY FOUND HERE
    Fits
    Tacoma 2005-2023
    4Runner2003-Present
    FJ Cruiser 2007-2014
    Lexus GX460 2010-Present
    Lexus GX470 2003-2009
    4x4
    $360
    YOU RECEIVE THE SET, AS PICTURED
    PreRunner 2WD
    $495
    FREE SHIPPING USA CONUS +HI +AK
    Canada +$120USD
    Terms of Sale
    Inspect the parts upon delivery for press service satisfaction.
    If any discrepancies are found contact me IMMEDIATELY.
    Do NOT attempt to install if any discrepancy is found.
    To expedite shipment, I preorder and keep parts on hand;
    payment reserves next available pair when not in stock.
    I am a press service,
    no other services or conditions are to be assumed.
    Everything pictured is included.
    All sales are final, no return for refund accepted.
    Warranty
    Provided by manufacturer, their conditions apply.
    4x4 Install
    Torque CV axle nuts to spec with a calibrated torque wrench.
    A loose assembly shortly after installation means your CV axle nut lost it’s torque.
    If the axle nut loses it's torque, forces acting on the assembly will ruin the bearing.
    Loan-A-Tool
    Torque Wrench (173 lb ft).....
    Socket (35mm)......................
    Puller (if difficult to remove)
    Loctite 241.............................
    Install tips
    Wire brush CV stub splines of rust/grime, wipe and apply anti-seize to splines (not threads)
    After insertion thru hub, clean stub threads with solvent, dry and then sparingly apply Loctite 263
    Torque axle nut with wheel on the deck
    Seals:
    Not included
    Knuckle....90316-A0001
    CV............90304-A0001
    Outstanding:
    cjlew13
    PreRunner:
    enigma429ad
  2. Mar 5, 2018 at 11:30 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
  3. Mar 12, 2018 at 8:03 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @05Taco4x4 do you have the ability to do Prerunner hub assemblies as well?
  4. Mar 12, 2018 at 8:25 PM
    05Taco4x4
    2TR-FE Enthusiast
    I do, you need a set?
  5. Mar 13, 2018 at 4:26 AM
    BassAckwards
    I might, but I have a few questions..
    - Do you use a Toyota hub flange for the prerunners? I've heard that they don't make an aftermarket flange for the 2wd prerunner trucks
    - Do you include a Toyota lock nut with these? (I believe this is a prerunner only part)
    - What is the cost for two prerunner hub assemblies? (both of the bearings on my truck are bad)
    - What else, will I need, besides what you include, to bolt these up and get my truck back in working order? I'm guessing maybe inner wheel seals?
    Thanks in advance,
    Robert
    hoverlover and Kolunatic like this.
  6. Mar 13, 2018 at 9:35 AM
    05Taco4x4
    2TR-FE Enthusiast
    Yes, there's no alternative hub.
    Yes, there is a lock nut that keeps the hub tight against the bearing.
    My hubs come with the O-ring, that is sandwiched between the bearing and steering knuckle.
  7. Mar 13, 2018 at 12:16 PM
    BassAckwards
    Thank you for all the info. Whats your lead time like on a pair of these?
  8. Mar 13, 2018 at 12:44 PM
    05Taco4x4
    2TR-FE Enthusiast
    However fast the components get shipped to me, I have them in mail the next business day (3-day shipping). I probably won't ever stock PreRunners.
  9. Mar 13, 2018 at 1:07 PM
    BassAckwards
    Completely understandable, I assume there's much less demand for them. I will keep you posted in the next few days as to whether or not I am going to go ahead with the order. I need to see if I can swing it this time around when I get paid, or if it is going to have to wait.
    Thanks again for all your help sir
    05Taco4x4[QUOTED][OP] likes this.
  10. Mar 19, 2018 at 7:38 AM
    BassAckwards
    I am going to hold off on buying these for a while. I went with a dorman assembly to get my truck back on the road until i can afford to fix it properly with an OEM bearing. Definitely keeping you in mind for future reference though as my truck seems to eat through front bearings every 30-40k miles.
    Thank again for all the info, its good to know there are members on here than can provide a quality assembly for prerunners & 4wd’s
  11. Mar 19, 2018 at 9:32 AM
    05Taco4x4
    2TR-FE Enthusiast
    I'm glad your truck is rolling, no worries I'll be here :thumbsup:
    BassAckwards[QUOTED] likes this.
  12. Mar 24, 2018 at 1:35 AM
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    Payment Sent! :spending:
    BassAckwards and 05Taco4x4[OP] like this.
  13. Mar 31, 2018 at 12:28 PM
    AKduckTaco
    AKduckTaco New Member
    Greg
    Thanks again 05Taco4x4 for the bearings. Fast response times and shipping as well. True to his word on components. Went right on after I got the old ones off(rent a slide hammer at O'Reilly's. Don't be a hero like me). Also replaced the rotors and pads while I was at it. No more slack in the steering. Wish I would of done this sooner.
    tmuhler, fast5speed, lo2hi and 2 others like this.
  14. Mar 31, 2018 at 12:30 PM
    05Taco4x4
    2TR-FE Enthusiast
    Awesome, thanks for the feedback
    lo2hi and BassAckwards like this.
  15. Mar 31, 2018 at 3:31 PM
    lo2hi
    Chiro
    Portland, Oregon
    Received all the parts! I just gotta install it now. Will be renting a slide hammer too :). A+ Fast response/shipping.
  16. Mar 31, 2018 at 4:32 PM
    05Taco4x4
    2TR-FE Enthusiast
    I'm glad I could help :headbang:
    lo2hi[QUOTED] likes this.
  17. Apr 1, 2018 at 9:38 PM
    jwgirby
    jwgirby New Member
    Justin
    Rapid City
    11' Taco TRD Sport
    TC upper/lower Kings Dakars CVT Tent/bedrack Clazzio Seats
    Do you have a set in stock? And how do I go about ordering it? Sorry I'm new to this site
  18. Apr 18, 2018 at 11:35 PM
    336
    336 Well-Known Member
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    Just replaced driver side bearing; believe the passenger is gone now.. Thinking about a pair of these right before i put on new tires.
    05Taco4x4[OP] likes this.
  19. Apr 19, 2018 at 4:06 AM
    05Taco4x4
    2TR-FE Enthusiast
    PM me when you’re ready. I currently have two pair on hand. I’m out of town, return Monday morning.
  20. Apr 22, 2018 at 11:29 PM
    lo2hi
    Chiro
    Portland, Oregon
    BUMP, no more wheel bearings noise! I finished the passenger, but I didn't replace with the Timken seal.
    I wasn't sure how to pop it out, and the one in there looked alright though. Still have the other one, but the road noise difference is crazy! :thumbsup:
