57k and half the Irridium plugs are eroded, half look good
Discussion in 'Technical Chat' started by richiec, Aug 23, 2013.
  1. Aug 23, 2013 at 6:58 AM
    richiec
    richiec [OP] Member
    Richie
    NJ
    2010 Toyota Tacoma Supercharged
    Supercharger, Short Shift, TRD Exhause
    I just took my 2010 Tacoma with the TRD supercharger into the dealer for a misfire. Turns out that half of the plugs had completely eroded electrodes and the other half looked perfect. I asked if the 3 bad plugs came out of the same side of the engine and they said they came from both sides. Dealer advised that it is normal wear since I am hard on the engine but I would think that would wear out all of the plugs, not just half of them. I suspect there is an underlying issue. Any ideas?
  2. Aug 23, 2013 at 7:00 AM
    richiec
    richiec [OP] Member
    Richie
    NJ
    image.jpgHere is a picture of one good and one bad plug that came out of the engine.
  3. Aug 23, 2013 at 7:09 AM
    12TRDTacoma
    12TRDTacoma Pulley Man ;)
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    It happens. Especially in FI applications. Due to the unnatural charge of air entering the combustion chamber at all times, stuff is bound to wear quicker. Don't worry about it.
  4. Aug 23, 2013 at 7:14 AM
    richiec
    richiec [OP] Member
    Richie
    NJ
    Thanks for the feedback. The fact that half are extremely eroded and the other half look almost new doesnt concern you at all?
  5. Aug 23, 2013 at 7:25 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    That ain't right, and not normal.
  6. Aug 23, 2013 at 7:38 AM
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    No. Because you are close to 60k. At 60k they are going to look like crap, especially when you are forcing extra air which isn't being intaken naturally.
    Either that, or someone pulled the plugs and "gapped" them at one point. Are you the first owner of the truck?
  7. Aug 23, 2013 at 7:41 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD OffRoad Poser ψ(`∇´)ψ
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    That looks bad
  8. Aug 23, 2013 at 7:48 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
  9. Aug 23, 2013 at 9:05 AM
    richiec
    richiec [OP] Member
    Richie
    NJ
    Any ideas as to what would be causing only half the plugs to erode? Dealer said they test drove the truck after installing the new plugs with the computer hooked up and everything seemed to be running fine. I would imagine their computer would see if a particular cylinder was running lean/rich, etc. Im at a loss...
  10. Aug 23, 2013 at 9:09 AM
    YOTA LOVER
    NH
    I wish I could help. My knowledge extends to making sure they are gapped properly and installation, that's it.
    Did you try a "search" to see if there are threads on the same subject?
  11. Aug 23, 2013 at 10:16 AM
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    Like I said. Were the plugs gapped? Are you the original owner. If you say yes and no in that exact order I could tell you why they look trashed.
  12. Aug 23, 2013 at 11:12 AM
    richiec
    richiec [OP] Member
    Richie
    NJ
    Yes, I am the original owner. Supercharger was installed by dealership the day I bought it. The truck had about 150 miles on it when the supercharger was installed since it was driven up here from a dealership in Virginia. Plugs were just replaced by the dealership. I would have to assume that they checked/gapped the plugs on the newly installed supercharger as well as the new plugs installed this week.
  13. Aug 23, 2013 at 11:34 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Holding up a brand new plug against one with 60+K miles looks like a perfect example of a burnt out plug. The new one is Iridum the other copper.
  14. Aug 23, 2013 at 12:17 PM
    richiec
    richiec [OP] Member
    Richie
    NJ
    Same exact plug. Both are Denso Irridium as specified by Toyota. The irridium is so worn out it looks like a copper plug.
  15. Aug 23, 2013 at 12:19 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    Did you wait till 60k to change them or did you do it at 30k and now 60k?
  16. Aug 23, 2013 at 12:33 PM
    richiec
    richiec [OP] Member
    Richie
    NJ
    I asked the dealer if I needed to do it as part of my 30k maintenance and they said they are good until 90k since they are irridium so I waited and it wasnt until I got a check engine indicator for misfires that I knew they needed to be changed.
  17. Aug 23, 2013 at 12:44 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    Well when you rush that much air it is going to be more harsh on our plugs, I would switch back to copper plugs and change them every 30k but I'm not sure if copper plugs are run with the sc, also are you running high octane everytime like your supposed to?
  18. Aug 23, 2013 at 3:52 PM
    YOTA LOVER
    NH
    Dirtier fuel with a S/C pushing more air... Higher combustion temps... Could explain the plugs eroding that much. Spit-balling, but seems logical.
  19. Aug 23, 2013 at 3:54 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    :thumbsup:
  20. Aug 23, 2013 at 5:21 PM
    worthywads
    None of that explains why 3 plugs are toast and 3 are not.
    Correct me if wrong but your photo is of 2 plugs that came from the same engine for the same amount of time, right? Your picture looks like a brand new plug next to a total meltdown, was the other a good used one?
