Discussion in 'Tonneau Covers, Caps and Shells' started by Boghog1, Feb 11, 2019.
  1. Feb 11, 2019 at 7:24 AM
    Boghog1
    Boghog1 [OP] Jack of all trades, master of none.
    Southern, NH
    2019 AC V6 4x4 SR
  2. Feb 11, 2019 at 8:32 AM
    11Bravo4x4
    11Bravo4x4 Well-Known Member
    Mitchell
    2018 Tacoma off road 4x4 quicksand
    I have the mx4 bakflip and can say it’s a great all around product. You still retain your cleats. Although you do relocate your rails it’s easily reversible and sounds worse then what it is. It’s reasonably dry but I did have to put some permatex silicone on the 2 front areas since there were really tiny gaps. It now is pretty darn watertight.
    Boghog1[OP] likes this.
  3. Feb 11, 2019 at 8:40 AM
    11Bravo4x4
    Mitchell
  4. Feb 26, 2019 at 8:42 AM
    Omarats
    Omarats Active Member
    Tom
    2018 White Tacoma Limited
    Yeah, I’m in the same boat and there just seem to be many, many tonneau options out there. The more I look, the more confused I get. I’m sure that I’d be happy with anything that I get, but I think I narrowed it down to the Extang Encore ($919) or the Fold-a-Cover G4 Elite ($795). I like the ability to access the bed from either end which helps limit my choices. I’d be interested to see if you have made a decision or made a purchase yet.
    Tom
    Tullie D and Boghog1[QUOTED][OP] like this.
  5. Feb 26, 2019 at 1:07 PM
    Omarats
    Tom
    Thanks for the update and the suggestion to check with Kyle or the other autoanything thread before making the purchase.
    They both seem like nice covers. As you mentioned, there does seem to be a ton of hardware for the G4 cover....which means the more likely something will come loose. I believe I read that the G4 does only require the removal of 4 bolts to remove it entirely.
    I’d be anxious to hear your initial thoughts on the encore once you get it installed and if anyone else has any opinions on with of these covers.
    Thanks!
