5lug and 6lug leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dillonk1602, Jan 5, 2018.
  1. Jan 5, 2018 at 8:02 AM
    dillonk1602
    dillonk1602 [OP] Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    difference between 6lug and 5lug leaf springs
    i know that 6lugs are spring over and that 5lugs are spring under but has any one put a 6lug leaf springs on a 5lug? that bolt in to the OEM placement.
    Trying to get more travel in the rear the dmz kit will work on the 5lug frame set up but everything said and done going to be about 4,000 or more! and that cutting everything off the frame
    i would like to keep the OEM front eyelid and change the rear hanger/shackle set up with new leaf springs but then i only have a 1 peace drive shaft so do i have to look in to ring and pinion angle and the drive shaft and tranny?
    just want to know what you guys think thanks!
