5lug Axle Info
Discussion in '5 Lug' started by Sperrunner, Jul 26, 2018.
  1. Jul 26, 2018 at 5:55 PM
    Sperrunner
    Sperrunner [OP] UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    This thread isn’t finished, i am working on it but hit post by mistake. If you have any more info let me know so i can add it in
    This thread is to give everyone a good understanding of 5lug axels and how they are different then 6lug axels
    Between 95-15 3 axels different axels were found under our trucks, the 7.5”,8.4” and 8.4” (for 2nd gen taco). All of these axels were set up for spring under axel (sua) vs the 6lug spring ove axel (soa). All used a softer 2 leaf pack vs the 6lug 3leaf pack. The e break setup was different from a 6lug in that the 5lug cable just went strait into the back of the drum while on a 6lug in soan across the axel and went to a mechanism on the outside of the axel.
    Toyota 7.5” axel 86-04 pickups and tacomas
    This is the smallest of the 3 axels. For tacomas this axel was found in 4cyl 5lug tacoma. It had a 27 spline count. It came with 2 different gear ratios Auto trans 3.58 manual trans 3.42
    Pre tacos had a more narrow axel but the 3rd was the same.
    There are a few options out there for different gears and lockers.
    Parts:
    https://eastcoastgearsupply.com/i-18849164-toyota-7-5-low-pinion-3rd-rear.html
    Additional info:
    http://www.f150hub.com/drivetrain/toyota-axles.html
    https://www.customtacos.com/forum/1...a-7-5-gear-ratio-question.html#/topics/141813
    Toyota 8.4” axel (1st gen tacoms)
    Found in v6 5lug tacomas, the axel is similar to the 6lug version and will take all the same internals. Came with a couple different gear ratios, s runner 3.15,
    Parts:
    https://eastcoastgearsupply.com/i-788575-tacoma-8-4-non-eld-t100-tundra-3rd.html
    https://parts.camelbacktoyota.com/p...iteid=214329&vehicleid=190379&diagram=8510540
    Toyota 8.4” axel (2nd gen)
    In all 5lugs. 2nd gens axel is 2” wider on either side and use different mounting points then 1st gens. They came with manual trans 3.31 auto trans 3.53 gears, but accept the same internals as the 6lug, it will even take the same diff from the earlier 8.4”.
    Parts:
    dasitmane420 and Bizquick like this.
  2. Jul 26, 2018 at 8:07 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I should note the 6 lug elocker axle shafts are 1/2 in longer than 5 lug and I'd assume 6 lug non elocker axle shafts. This is why Im 6 lug in the rear :( I did try to swap them but no game. Also 2nd gen 5 lug with auto is 3:53 gears.
  3. Jul 26, 2018 at 8:11 PM
    Sperrunner
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The elocker housing is different then a non elocker housing.
    But non e locker houseig should be the same as a 8.4” from a 1st gen other then length and the spring perches
    dasitmane420 likes this.
  4. Jul 26, 2018 at 8:26 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Yup I just wanted to clarify in case someone decided to follow what I did.....The locker is so worth it though lol
  5. Jul 26, 2018 at 8:27 PM
    Sperrunner
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Why you go with a new axel vs just putting a arb or Detroit in it. Would of been simpler
  6. Jul 26, 2018 at 8:29 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I got the whole axle for $400 and the new leafs for $100 so around $550 with some tools I didn't have, I got a locker with a slightly better gear ratio. I was looking at an arb but you cant beat that price lol
  7. Jul 26, 2018 at 8:30 PM
    Sperrunner
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Damn you cant even get your 3rd regeard at ecgs for that price lol
  8. Jul 26, 2018 at 8:38 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    An arb alone is close to a grand and I wanted a selectable locker still. I will still regear eventually but for now its got enough pep for that I need. (Also I may have a mk3 supercharger to go in :spy:)
  9. Apr 19, 2020 at 12:30 PM
    TacosELg
    TacosELg Member
    San Diego, California
    96 Tacoma Ext Cab 2WD 5 Lug
    Ok im reviving another old thread but here we go, im looking to swap out my axle on my 5 lug tacoma. Im trying to figure out what gear ratio i currently have 96 tacoma V6 auto, but want to convert it to a manual and swap out the axle with something bigger but want to know what is compatible with what, tried searching and keep finding info on 4 bangers and 6 luggers.
    Beeman1 likes this.
  10. Feb 2, 2022 at 5:09 PM
    Krzykraker
    Krzykraker Well-Known Member
    1998 Toyota Tacoma Base, 2.7L, 4wd, Regular Cab, Shortbed
    Are you possibly saying that I could take a 5 lug axle from a 2wd 1st gen tacoma with a V6 and swap out with 6 lug axleshafts from a 4wd 1st gen tacoma with a 4 cylinder in it?
  11. Feb 2, 2022 at 6:54 PM
    Sperrunner
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yes and no.
    yes you would make it a 6lug. But you will end up with a SUA 6lug axle when you need a SOA 6lug axle.
    you will also have some weird gear ratio in the diff.
    but other then that its just a normal 8.4 axel
  12. Feb 4, 2022 at 5:32 PM
    Krzykraker
    Actually, what I'm trying to do is SUA. So this would be what I've been looking for. From what I've read over the past several months, with SUA you get a better ride and less axle wrap. Also I want to lower my rear a few inches.
  13. Mar 27, 2025 at 4:28 PM
    Acivichb
    Acivichb Well-Known Member
    Jordan
    Maui hawaii
    Suzuki Sammy. 3rd Gen tacoma
    Aloha sorry to start this thread up again. I am looking to put a arb locker in my 2007 2wd 4cylinder manual Tacoma. Would it be the same locker used in the v6 verson.?,,
  14. Mar 27, 2025 at 7:07 PM
    Sperrunner
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If you have a non elocker 8.4 rear axle you just need to get a locked for it regardless of engine.
  15. Apr 9, 2025 at 1:13 PM
    trinidadlad
    trinidadlad Well-Known Member
    Dakota
    08 white base 5lug
    Sorry for dumb question but which is better for the 1st gen? I bought a LT 2004 5 lug and im going through and trying to beefup and clean up everything I can, idk much about axles but im eager to learn. I want to keep close to oem but "built" so would I be best to buy a housing for a 95-04 8.4" 5 lug and swaping that it? Ill confirm what's under the truck after work
  16. Apr 9, 2025 at 1:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Why does what you have need beefing up?
    There are cases that benefit. Curious what yours is. Adding boost?
  17. Apr 9, 2025 at 1:47 PM
    trinidadlad
    Dakota
    08 white base 5lug
    The plan is eventually to swap in the built yota 1 2rz with the supercharger from lce, but in all honesty I think it's just a fixation with wanting to make everything on the truck the best version of it possible. Im even looking at the rear disk break conversion from hellsgatehotrods just cause.
  18. Apr 9, 2025 at 2:54 PM
    trinidadlad
    Dakota
    08 white base 5lug
    Or o guess maybe since I've got the total chaos long travel I could swap to the 2nd gen axle since its wider? I'm assuming there isn't much aftermarket support either way
