5sp to 6sp trans swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jason smith, Apr 2, 2011.
  1. Apr 2, 2011 at 9:29 AM
    jason smith
    jason smith [OP] loblk08taco
    Tennessee
    08 sr5 2wd 5sp 2.7
    flowmaster 40 series orig flo, cold air intake,painted headlights.Trex eyelids, xrunner wheels, street tacos 3"drop rear, djm 3" drop front
    didnt know, just wondering if a 6sp xrunner trans would bolt up so a 08 2.7 liter engine, it has a 5sp in it now.
  2. Apr 2, 2011 at 4:21 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    6 speed? Let's get a group buy going for GEAR VENDORS OVERDRIVE units and have 10 :eek: speeds!
  3. Apr 4, 2011 at 9:31 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Or even getting a slightly better ratio for 6th gear made by someone would be great in itself.
    I'd pay for the gears to be cut, then throw em in there. Be fantastic.
  4. Apr 4, 2011 at 2:49 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I'd be interested if it is a higher gear ratio and therefor better highway MPG.
  5. Apr 4, 2011 at 5:17 PM
    JLeBlanc
    JLeBlanc New Member
    sorry wont work, x-runners have v-6s and are completely different motor wise
  6. Apr 5, 2011 at 6:54 PM
    johnybtacoma
    johnybtacoma Member
    Johny
    Boston
    02 Tacoma SR5 4x4
    Anyone know if a 6 speed from a nwer tacoma 4x4 4cy. would line up with a 2002 4x4 4cy.? I need to pull the tranny to replace a bearing and was thinking of the almighty MPG (I have a 1 hour communte each way) and though 6 is better then 5.
  7. Apr 5, 2011 at 7:12 PM
    JLeBlanc
    JLeBlanc New Member
    four cylinders do not come with 6 speeds only v6s
    also the 6 speeds have such a low first gear ratio that top gear ratio is not that different so gas mileage would not improve much
  8. Apr 6, 2011 at 2:28 AM
    george3
    new jersey
    tacoma
    Well, there you go, not any reason to do it. Toyota should make a 6 speed with higher ratio on the 6th gear for better highway MPG. Most of my drive to work is highway and interstate so it would help my bottom line.
