5spd 98 tacoma 3RZ-FE engine removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KYTacoma98trd, Feb 8, 2015.
  1. Feb 8, 2015 at 6:39 AM
    KYTacoma98trd
    KYTacoma98trd [OP] Active Member
    Jeremy
    Taylorsville,Ky
    98 Tacoma Ext. Cab TRD
    3 inch Rough Country lift kit, Rough Country shocks in the rear, Gabriel starts in the front, 31 inch tires, Alpine deck and speakers. Just upgraded head lights and side markers. Added K&N intake, Pacesetter Header,& Gibson Exhaust
    Does transmission need to be removed with engine or can I just remove engine itself? I keep hearing different stories and just want to know the easiest way to go about it! So far just getting to timing chain and secondary chain has been undesirable!
  2. Feb 15, 2015 at 8:19 AM
    KYTacoma98trd
    Jeremy
    Taylorsville,Ky
    Seriously, no one has any input, Wow!
  3. Feb 15, 2015 at 9:08 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    It can be done to just pull the motor. It be like a reverse clutch replacement. Going to be a pita trying the line it up when it goes back in. You'll have to undo all the motor mounts and find a way to hold every thing.
    I haven't done a 4x4 motor pull yet, but I'd drop the transfer case first and pull the motor and tranny out together for the least headache.
  4. Feb 15, 2015 at 9:12 AM
    KYTacoma98trd
    Jeremy
    Taylorsville,Ky
    Thanks, I have motor mounts out, all the bolts out! Engine is on hoist and have pulled engine about two inches from bell housing but it just won't let go!
  5. Feb 16, 2015 at 7:58 AM
    MadTaco461
    CA
    Kinda stock
    The input shaft is longer than 2" (insert that what she said) gotta wiggle the tranny back until you clear the clutch
  6. Feb 22, 2015 at 11:30 AM
    KYTacoma98trd
    Jeremy
    Taylorsville,Ky
    Finally out!
  7. Feb 22, 2015 at 11:34 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Curious as to why you posted in 2nd gen, instead of 1st gen...?
    Might get more input.
  8. Feb 22, 2015 at 11:44 AM
    KYTacoma98trd
    Jeremy
    Taylorsville,Ky
    Thought everything from 98 to 04 was second generation? If not my bad!
  9. Feb 22, 2015 at 11:50 AM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
  10. Feb 22, 2015 at 11:54 AM
    KYTacoma98trd
    Jeremy
    Taylorsville,Ky
    Ok thanks for clearing that up!
