5spd Bleeding Clutch Need Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassAckwards, Jun 22, 2018.
  1. Jun 24, 2018 at 1:57 PM
    #61
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm curious about the adjustment at the master cyl pushrod. Where is the adjustment nut? Is it extended all the way to the end of the threads, or in the middle somewhere?
    Back up to the first post. Before you touched anything, you said the clutch was grabbing up high, close to the dashboard. This is usally an indication that the clutch disc is getting thin. The pushrod nut isn't really there to be adjusted. The hydraulics aren't going to "go out of adjustment" on their own. They either leak (and the pedal goes to the floor) or you have a clutch problem.
    You may have caused more confusion by messing with the adjustment first. I would try to get it Back close to where it was at the beginning and then try bleed it again.
    BassAckwards[OP] likes this.
  2. Jun 24, 2018 at 5:08 PM
    #62
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Its somewhere in the middle right now. I just let all the air out of the front tires, jacked up the rear end and im gravity bleeding it right now. Hopefully something works really dont want to start replacing parts
    It was grabbing up higher after i adjusted it because the adjustment lock nut came loose during a 3000 mile road trip. Before that it was driving like normal, grabbing 25%-40% from the floor.
    I dont think the clutch is worn out, even though its lived a hard life, its only got 40k on it. I got 200k out of the last one and it still wasnt slipping.
    I am going to adjust it back closer to where it was and then bleed it again. Looking back, i never should have messed with the adjustment. Major screw up on my part:(
    b_r_o[QUOTED] likes this.
  3. Jun 25, 2018 at 7:00 PM
    #63
    BassAckwards
    Thank you again to everyone who posted up in here! Got the clutch bled at last. As some of yall suspected, it was partially a push rod adjustment issue, but i think what was giving me the most issues was the fact that the bleeder was leaking around the threads. Put some teflon tape on it and backbled everything using the brakes. Then when i got the pedal back to about 60% pressure, i adjusted the pushrod and got it back to where it was before i started this whole mess. Clutch pedal still engages at almost the top of the pedal throw, so im assuming my clutch is nearing the end of it's life.
    It's folks like yall that make this forum great, and help attract new members. Thanks TW fam! :hattip:
  4. Jun 25, 2018 at 7:37 PM
    #64
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    OP = :benchpress:
    Me = :headbang:
  5. Jun 25, 2018 at 7:44 PM
    #65
    BassAckwards
    :bowdown:
  6. Jun 28, 2018 at 6:35 PM
    #66
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Glad it got sorted!!
  7. Jun 28, 2018 at 7:04 PM
    #67
    BassAckwards
    Me too man! Thanks again bud!:fistbump:
    MrCrowntown[QUOTED] likes this.
  8. Jul 9, 2018 at 10:21 AM
    #68
    dragonmaster839
    dragonmaster839 Member
    San Diego, CA
    2006 Tacoma TRD
    I recently replaced slave cylinder, TOB, clutch. Now my clutch pedal is leaking at the master cylinder. I think I need to replace that too. A lot of fluid leaking on my floor mat from the clutch pedal. Can anyone recommend a replacement master cylinder? Having a hard time deciding what to order. A link would be helpful. Thanks!
  9. Jul 9, 2018 at 12:34 PM
    #69
    BassAckwards
    Is your truck a 6 speed, or 5 speed?
    Might be a stupid question, but looks like you have a 6spd trd sport in your pic.
    From what ive read, it seems like most people are rebuilding the clutch master with an OEM rebuild kit. I dont know of many aftermarket options that are quality
    Edit: i think the 5 and 6 speeds share the same clutch master
    b_r_o and scottalot like this.
  10. Jul 9, 2018 at 1:58 PM
    #70
    dragonmaster839
    San Diego, CA
    2006 Tacoma TRD
    Thanks.
    6 speed. Wouldn't know whether 5 and 6 speed are the same. Most aftermarket options are $40-$60. Which makes me think they aren't great quality. Or maybe I'm just getting ripped off paying $120+ for OEM......
  11. Jul 9, 2018 at 2:01 PM
    #71
    BassAckwards
    Yeah i personally would go with oem if you can afford it. Might keep you from ending up on the side of the road stranded later on
  12. Jul 9, 2018 at 5:06 PM
    #72
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    @rjbiii has good advice, if you can afford it go OEM. These trucks hold their resale value. Even more so if you're using OEM stuff. 60 bucks gets used up quick on the back of a tow truck.
    On my 2011 the clutch pedal squeaked. I got it replaced under warranty at the dealer. Not sure if your 07 is covered but there is probably an updated design m/c available at the dealer.
    scottalot and BassAckwards[OP] like this.
  13. Aug 10, 2018 at 7:21 PM
    #73
    BassAckwards
    The pushrod assembly inside the cab started leaking today.. i think that could be part of the reason as to why it was so difficult for me to bleed the clutch pedal recently. Does anyone have an oem rebuild kit part number, or do yall recommend just replacing the whole assembly?
    Also ive read that it can sometimes require bench bleeding to get all the air out, any tips or a write up on this? I feel like my truck is on borrowed time, and since my other truck is out of commission, id like to address this problem before it leaves me stranded on the side of the road
  14. Aug 10, 2018 at 7:59 PM
    #74
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Use a bench bleeder kit. you can make one with a short piece of brake line/fitting and some vacuum line.
    Or just skip the kit and stroke it a few times while pouring fluid in slowly. The clutch master went really fight you because it only has one line coming off it. It's the brake master cylinders with multiple lines that can bite you if you don't bench bleed them carefully.
    Once it's back in the truck then you know what to do
  15. Aug 10, 2018 at 8:06 PM
    #75
    BassAckwards
    Good tip, ill probably go this route :fistbump:
  16. Aug 11, 2018 at 9:03 AM
    #76
    BassAckwards
    Was able to track down the part numbers for the clutch master cylinder (pushrod assembly), and was wondering if any of you folks knew if they were interchangeable between year models? From my research, i think the 13-15 is a TSB revised # to address the squeaky clutch pedal. Would like to put the 13-15 part in there if it's compatible.. Anyone have any info on this?
    '05-'12: 31420-04011
    '13-'15: 31420-04020
  17. Aug 11, 2018 at 10:28 AM
    #77
    Muddinfun
    Muddinfun Well-Known Member
    Someone just recently wanted to update their truck to the newer non squeek version. You have to replace the pedal and some other stuff. I think it was about $300 for all the parts.
  18. Aug 11, 2018 at 10:32 AM
    #78
    BassAckwards
    Good to know, thanks for the heads up
  19. Aug 11, 2018 at 10:37 AM
    #79
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    @Muddinfun is correct. When my 2011 had the updated clutch master installed to address the squeak, it was a big assembly with a pedal and master cyl all mounted on a big bracket
  20. Aug 11, 2018 at 10:39 AM
    #80
    BassAckwards
    Think ill just stick with the old style one. Not too worried about the squeaky pedal. My '13 6spd has the updated assembly, and it still squeaks
