5spd trans noise in neutral - HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Green1GT, Jan 21, 2023.
  1. Jan 21, 2023 at 5:24 PM
    Green1GT
    Green1GT [OP] Well-Known Member
    Maryland
    Hey guys,
    Not the post I was expecting to make this Saturday evening.
    1999, 2.7, 4x4. Fired the truck up a few minutes ago. Started fine, but as soon as I let the clutch out (in neutral) I got a rattling noise (sounds like a machine gun, about 500 rpm lol). I can feel this shaking through the shifter knob.
    The noise ONLY HAPPENS WHEN CLUTCH IS FULLY LET OUT IN NEUTRAL. Noise is not present when I begin to release clutch in 1st, however, the clutch does not feel like it is working properly- the truck is bucking while slipping it.
    I replaced the entire clutch assembly summer of 2021 - very confused - and I would seriously appreciate any advice as to what this could be. Less time I have to waste doing research. The truck is my daily so I guess I'm pulling the trans tomorrow in my driveway.
    Thanks.
  2. Jan 21, 2023 at 5:28 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Sounds like the pressure plate or disc has issues.
    wilcam47 and Green1GT[OP] like this.
  3. Jan 21, 2023 at 5:36 PM
    Green1GT
    Maryland
    Another thing - speed of knocking increasing with engine RPM
  4. Jan 21, 2023 at 6:30 PM
    fxntime
    Really, the only other thing that I didn't mention is the main shaft bearings in the transmission and I'd rather it be the clutch or pressure plate. Either way, you'll have to drop the transmission to find out what it is.
    Green1GT[QUOTED][OP] likes this.
  5. Jan 21, 2023 at 8:11 PM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    Since you recently replaced the clutch assembly...do you remember if you properly torqued all the fasteners on the pressure plate? You are looking at dropping the tranny regardless.
    wilcam47 likes this.
  6. Jan 21, 2023 at 8:20 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Clutch release bearing .
    Might be the fork starting to break
    Last time you parked the Truck all was fine?? No strange noises?
    These things tend to have signs before failing .
    Outside in the rain perhaps water seeped into the bell housing now you have ice where there should not be anything.
  7. Jan 22, 2023 at 6:43 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Green1GT[OP] likes this.
  8. Jan 22, 2023 at 8:58 AM
    Green1GT
    Maryland
    Yes I did - and I even torqued them in the correct order (Aisin specified)
  9. Jan 22, 2023 at 8:59 AM
    Green1GT
    Maryland
    I have a feeling it may be ice - I have been in Colorado for a week and I came home to this. I'm going to let it warm up and see what happens. The truck was absolutely fine before this. No noises, shifting smoothly.
    Bivouac[QUOTED] likes this.
  10. Jan 22, 2023 at 9:40 AM
    Green1GT
    Maryland
    I can't believe it but - IT'S GONE!
    It was making the noise and still acting weird when I first rolled out of the driveway, but as soon as I shifted into second, all the issues went away. No more noise, no weird shifting. I assume ice was built up somewhere in the clutch assembly.
    Thank you everybody. I cannot explain the relief I am feeling right about now haha.
    Bivouac and SilverBulletII like this.
  11. Jan 22, 2023 at 2:16 PM
    Bivouac
    I have seen strange things happen over the years!!
    Glad it appears to be fine!
  12. Jan 22, 2023 at 3:32 PM
    1schoir
    Freeport, NY
    Quite a remote diagnosis by Bivouac!:bowdown:
    Now that it's behaving properly again, you might want to look at how water got in there in the first place and see if you can prevent that in the future.
    Bivouac likes this.
