5speed "jolt" between gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by TRDtaco99, Apr 25, 2020.
  1. Apr 25, 2020 at 1:35 PM
    TRDtaco99
    TRDtaco99 [OP] Active Member
    1999 TRD tacoma 4WD 5spd
    I get a pretty noticeable little "kick" when I release the clutch in my 5 speed. The slower I release the clutch less harsh the kick is. It happens on all gears when shifting. I know manual cars will kick if you release the clutch too fast, but mine is definitely more sensitive and less forgiving than any other high mileage manual I've driven, to the point where I want to fix it. Does this sound like a clutch thing or a transmission thing? Any help is appreciated, just seeing if anyone else has had this experience. The truck has 240k miles.
  2. Apr 25, 2020 at 3:27 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I think I would check the Engine and transmission mounts something major loose in the drive train.
    It is one thing to dump the clutch completely different then what your describing at least to me.
    I have only had something like you describe with something broken
    Wulf likes this.
  3. Apr 25, 2020 at 4:10 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs
    Sounds like the clutch to me.
    My .20 fwiw...
    One alternative and easy check is a common problem for our older Tacomas.
    The plastic bushing that the shifter ball seats in, usually wears out around 100k.
    You have probably replaced this I would assume.
    If not, pay attention to your shifter as you release the clutch shifting gears.
    If you feel a simultaneous jerk in the shifter that could indicate this as your problem.
    With this worn out bushing my transmission was popping out of gear when I would release the clutch.
    This was because the shifter could not align the transmission gears properly.
    Its a super easy fix.
    MountainPassing likes this.
  4. Apr 25, 2020 at 5:00 PM
    TRDtaco99
    It always goes into gear nicely, no grinds or popouts, only when disengaging the clutch in a new gear. But ill look out for that.
    Wulf likes this.
  5. Apr 25, 2020 at 6:36 PM
    MountainPassing
    MountainPassing Well-Known Member
    01reg.cab 2.7 stick, 97 80-series 40th anniversary model
    idk but maybe make sure your not on the throttle pre-maturaly,that will jerk things if your in a hurry. just an idea
    robssol likes this.
  6. Apr 26, 2020 at 9:06 AM
    TRDtaco99
    :thumbsup:
  7. Apr 26, 2020 at 9:12 AM
    Wulf
    Wulf no brain just damage
    Kira
    1789 28th St, Boulder, CO 80301
    rock raisin
    In addition to the transmission and motor mounts checkout your driveshaft carrier bearing
  8. Apr 26, 2020 at 9:18 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Then your jolt might be something I don`t even pay attention to any more .
    Does it happen just pushing the clutch without shifting letting off on the throttle let you were shifting at like 40 mph or so.
  9. Apr 26, 2020 at 1:14 PM
    TRDtaco99
    It happens when I release the clutch in gear. I believe it's most noticeable when in the lower gears (which makes sense). I have to be extra easy when releasing the clutch for it to shift smoothly.
  10. Apr 26, 2020 at 1:16 PM
    TRDtaco99
    How can I check for these things? Give em a good shake? or...
  11. Apr 26, 2020 at 1:27 PM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    A jolt indicates to me that there was load on the clutch when you released it, so either torque was being transferred from the wheels to the engine or vise versa. So, maybe, assuming your not on the gas or engine braking, it isn't releasing as you would expect. That would lead me to looking at the master/slave cylinder and checking to see if they move smoothly.
    TRDtaco99[OP] and Kiloyard like this.
  12. Apr 26, 2020 at 3:10 PM
    TRDtaco99
    Makes sense, Ill check it out
  13. Apr 26, 2020 at 3:28 PM
    Wulf
    Kira
    rock raisin
    If there is much play when you give it a good shake by hand it's probably bad
  14. Apr 26, 2020 at 8:29 PM
    Glamisman
    Glamisman Well-Known Member
    I am guessing that it is related to spring wrap. A cheap way to "fix" this is to put an (AAL) add a leaf in.
  15. Apr 26, 2020 at 8:58 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    A video is worth a thousand responses.
    0xDEADBEEF likes this.
  16. Apr 27, 2020 at 11:34 AM
    TRDtaco99
    I replaced all my leafs when I installed the ICON rear leaf pack
  17. Apr 27, 2020 at 11:35 AM
    TRDtaco99
    Might be challenging since its more of a "feel" thing but i'll give it a shot.
  18. Apr 27, 2020 at 5:22 PM
    TRDtaco99
    Well, the problem is no more! All it took was flushing the clutch fluid. Happy it was something simple.
  19. Apr 28, 2020 at 9:03 AM
    Wulf
    Kira
    rock raisin
    :bananadance:
    TRDtaco99[QUOTED][OP] likes this.
  20. Apr 28, 2020 at 10:32 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Could it be the slip yoke sticking?
